911 running to cool?
Hello guys!
Been reading a bit on oil temperatures, and that leads to believe that my car might be running a bit to cool... After 5-10 minutes with slow warm up driving, my car gets to around 120. After 15 minutes of driving it is in the 140-150 range. In slow traffic I rarely see more than 160, highest I've seen is 180 after an hour in stop and go. My car has been run in California, so perhaps the thermostat is a bit to willing for the Norwegian climate? It is a 1979 3.0 With oil cooler.. What do you think guys? Thanks! Cheers, Jarle |
What is the outside temperature when you are driving? After 15 minutes of driving and the temperature is 140-150, check to see if the two oil lines to the front cooler are hot. If the cooler and the lines are heating up, the thermostat may be stuck open. Oil should not be going to the front cooler at those temps.
Ed 1973.5 T |
Possible thermostat issue?
As noted , all relevant to outside temps.......(real world). Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
PRO Motorsports
Either you have a mismatched sender and gauge, or you have a malfunctioning or non-existing thermostat for the auxiliary oil cooler.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
911 running too cool. huh, i had to check this on e out. who would have ever thought.
There is another possibility. My car was running hot and apparently the thermostat to the oil front cooler can have the thing that activates it removed. The result is that you essentially have an open thermostat and oil flows to the front oil cooler as soon as the engine is started.
I once took mine to the mechanic because I thought the thermostat opened too late and apparently they removed the plug inside the thermostat. The result was that after driving in Miami (80-90F) for over half an hour, it still wouldnt reach 180F which is about ideal. I took it back, they replaced the innards of the thermostat and once again, it allowed the vehicle to warm up normally. Check if you can feel oil pumping or a slight temperature change in the oil lines to the front cooler after you start it up cold.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 07-14-2010 at 07:54 AM.. |
The thermostat is located just in front of the right rear tire.
Ed 1973.5 T |
It shouldn't open until it reaches 180 F. roughly, I believe. So the oil should stay at 180 at a minimum. |
I don't think the thermostat is missing or stuck open. But I don't think it is an original SC thermostat either. To me it seems the thermostat is working, but is opening much to early. My guess is around 140.. I guess I can change the internals somehow? Which part am I looking for? Porsche 911 & Carrera Oil Circulation - Page 3 Thanks! Cheers, Jarle |
Can you post a picture so we can see if your thermostat is original. Any numbers on it?
Ed 1973.5 T |
I don't believe the thermostat would make any difference. After 15-20 minutes of driving everything should be warmed up no matter what cooler/thermostat you have. No 911 engine will run at 160 degrees. Your problem is most likely a bad or incorrect guage/sender. Do you have a numeric oil temp guage?
Registered Lunatic
ANYway, whether you choose to go through that or not, double check the sender. I think that many senders that should be 150C max have been replaced with a 200C max sender thereby give false readings on the low side. You'll have to identify your gauge though and ensure exactly what sender it needs.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! Last edited by d.a.autry; 07-15-2010 at 07:28 PM.. |
It shows around 70-75C on the outside of the oil cooler pipe by the front wheel. It also measures about 75C on the outside of the oil reservoir. The gauge still shows about 140 F, which leads me to belive the sender and gauge is missmatched. 70-75C on the outside must mean 5C to 10C higher on the inside, meaning that my thermostat is probably working OK. The oil will probably cool a bit along that long pipe, so it is likely the oil is more than 10C hotter than what can be measured on the outside. Any comments anyone? Cheers, Jarle |
Either your gauge is bad, your sender is bad....or the two are mismatched.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
