-   -   A/C compressor switch (http://forums.pelicanparts.com/porsche-911-technical-forum/554634-c-compressor-switch.html)
llangston1 07-22-2010 11:44 AM
Has anyone installed a separate A/C compressor switch in their 911? I would like to be able to use the evaporator fan to circulate air through the main dash vents without engaging the compressor. The fresh air system is basically useless in getting any reasonable airflow in the car. My Miata had a separate button that was pushed to engage the compressor and a rotating knob that varied the fan speed. Can that be done with our systems.
Justin@Athens 07-29-2010 01:47 PM
bump, for an outstanding question. I would like to do something like this as well.
GH85Carrera 07-29-2010 02:02 PM
I did a simple cutoff switch for the compressor. Just put a toggle switch on one of the wires going to the compressor. When I flip that switch the compressor can't run. Then I can run the AC fan which blows right on me. It does not blow cold air but it blows.
The only time I use it is during autocross or DE sessions. I always run it at MAX fan speed.
Justin@Athens 07-29-2010 02:49 PM
Glen if you get a chance hit me back with some pictures.
cmonref 07-29-2010 04:55 PM
If you turn the temperature switch fully CCW, it clicks and the compressor turns off.
kuehl 07-29-2010 06:55 PM
You can splice the switch in either the green wire going to the thermostat switch or the green/white wire exiting the thermostat, or as Brian suggested you could play with having the thermostat set at one click to the right of the off position.
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_AC.jpg
GH85Carrera 07-29-2010 07:24 PM
My thermostat switch has no clicks. It rotates smothly.
kuehl 07-29-2010 07:30 PM
"Click" as in degree's. 12 o'clock is off. Turning CCW a few degree's.
