Taking it apart is easy
More mystery parts
It seems as though the bracket shown below held a tank of some kind and the plugged hose connected to that tank. What was the tank for, and why does the car run fine without it?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
loose nut behind wheel
could have been for the charcoal cansister. Part of you fuel vapor recovery system.
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
Yep, that held the canister and the hose is the feed into the intake. Your car is running fine because these are vapor emissions parts and do not relate directly to running. Just be sure no fumes are escaping anywhere along the plumbing in the engine compartment and trunk.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I see that didn't take long. Ann my indispensable red jack is in the photo too!
Wally in Montreal, Canada My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!) |
Location: A scenic and exhilarating drive along the Delaware River just one hour from Philadelphia, PA
I would have guessed that was the mounting bracket for the fuel filter. Where is the fuel filter mounted?
Ha Ha. Wally you type too fast. . .
Yesterday, Wally (Red 2.7) and I got the engine and trans out of my '74, and that's Wally's red jack visible down there. Wally was a fantastic help in doing this job. Really, he was the driving force and we got the removal done in record time. I want to publicly thank him for his help. My sincere appreciation to you, Wally - it would have taken me ten times as long to do the removal by myself. And, thanks for the loan of so many tools. Met Wally through this forum.
Fuel filter is mounted on the left hand side of the engine bay, in front of the CDI unit. It is connected with the fuel accumulator--look in the side wall area, just beside the engine lid hinge.
Ossiblue you are everywhere!
Brain fart on my part. I did not look at the picture carefully enough. I thought that was the left side of the engine compartment but upon closer inspection obviously it is not.
Gee Jerome sniff.. . aww shucks it wern't nuthin...
