-   -   Need some help (http://forums.pelicanparts.com/porsche-911-technical-forum/554885-need-some-help.html)
tonypeoni 07-23-2010 08:57 PM
Need some help
SmileWavy Whats this hose go too? AC I'm hoping. And where do these grounds go?? My car was in a body shop for about a year and they left more than a few things off the car.. Also I believe I have water in the fuel system as I have a awful misfire across the the whole rev band but particularly at idle. Is it safe to use some of the fuel treatment that claims to remove water from the fuel system? I may also have a bad cdi box:confused:
http://forums.pelicanparts.com/uploa...1279943803.jpg
http://forums.pelicanparts.com/uploa...1279943844.jpg
http://forums.pelicanparts.com/uploa...1279943860.jpg
HarryD 07-23-2010 09:30 PM
The ground strap goes to the engine lid. Connect to one of the bolts holding the lid.
tonypeoni 07-24-2010 04:54 AM
bump
BoxsterGT 07-24-2010 04:56 AM
You are correct, its an A/C hose.
Len
tonypeoni 07-24-2010 05:01 AM
Thanks much, Now what to do about water in the fuel system.. Would something like the product HEET damage my car?
E Sully 07-24-2010 06:09 AM
Your best bet is to drain the tank completely and make sure there is no rust and corrosion inside. If you don't you will just continue having problems.
