Hello Everyone,
![]() I not sure what these electrical connectors connect to when I install the engine. Could you please give an idea, the car was a roller and I didn't have a chance to take pics with engine installed. (#3) Is a larger diameter green colored wire(difficult to see the color in the pic). (#4) Is the small rubber hose for the charcoal canister? I dont have to pass smog, and wont be running the can. So could I just tie it off and hide it? Where does it continue on to? ![]() Thank you very much, ![]() Gene |
Alii&Maui
#3 looks like engine mounted heater blower for cabin heat.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Yeah, that's what I thought too...
#4 goes to the pod behind the left headlight above the fluid container. You can remove the container on the right wall of the engine compartment.
Bruce |
Oh yeah, I've seen that pod before, that's what its for.
Thank you Bruce ![]() |
