brooklyn ny 11234
930 slant nose's Avatar
1989 porsche guage removal
How do you remove speedo or tach from stock car
thx in advance
Old 07-24-2010, 02:25 PM
peppy's Avatar
The gauges just push in. Use something that will not mar or scratch to pry them out, take your time and work your way around the gauge. Once you get one out you can reach in and push the one beside it out.
Make sure to label wires and pictures help.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-24-2010, 02:35 PM
Zeke's Avatar
He's right and they can be stuck in there pretty good.
Old 07-24-2010, 03:02 PM
brooklyn ny 11234
Thank you for your reply
Old 07-24-2010, 03:28 PM
Weekend Mechanic
vulcan300's Avatar
The best way to get the gauges out is to push from behind. You can get to the backs of the gauges from the front trunk. A solid push will get them moving. If you start with the gauge furthest left you may have an easier time removing the bigger gauges like the tach and speedo. Remove the first one with a push from behind, then use the opening in the dash to remove the second one, and repeat. To pull the tach you'll need to remove your steering wheel. The tach is big and is a tight fit when removing it so use some painters tape on the top of the powder-coated steering column to protect it.
I learned all of this first hand as I've taken my gauges out to fix the odometer and put in electroluminescent-wire lighting. My fellow Pelicans deserve a big thanks for the great threads that helped me do that project.
Good luck,
J
86 911 Carrera Targa
Old 07-24-2010, 03:32 PM
just pull out the clock or something easy, then push the speedo out from behind, then the tach. Find one that is loose enough to pull out with your fingers, then push the rest out, working toward the tach.
Old 07-24-2010, 06:23 PM
brooklyn ny 11234
thanks for all you guys that helped me
Old 07-25-2010, 01:57 PM
Hodgey's Avatar
+1 on getting the clock out first
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 07-25-2010, 03:08 PM
Under the radar
Trackrash's Avatar
... Then coat the rubber seals with talcum powder before replacement. That way you will be able to get them out again, if needed, without a hassle.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-25-2010, 04:56 PM
