Oil line replaced
I changed the hard oil lines and engine oil line.
Does this look correct? I was not sure about the flow direction anymore. I find the Bentley pictures not very precise. Questions 1: The thermostat fitting closer to the wheel wall goes to the engine hard line and the other comes from the tank, right? Question 2 : I noticed the new rubber material differs from the old lines. Is is OK to have the rubber parts of the oil line so close to the hard lines? Frank ![]()
81 SC, www.frankschroeter.com |
Looks correct to me. I just replaced the oil line to the engine for an exhaust back date.... the oil line closest to the fender well went to the engine....
Alan |
MBruns for President
Yep -- looks correct to me too
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Looks nice. The rubber line might need to be tie wrapped back a bit to avoid rubbing against the tire (depending on how wide the rubber is you're using. I found mine had to be pulled back after finding a rub mark from being on track.
Tony G 2000 Boxster S |
