brooklyn ny 11234
930 slant nose's Avatar
1974 911 s how do you
Tell if this is a real s it has 10 digit vin it has fuel injection and original factory fuchs
thx in advance mike
Old 07-24-2010, 04:34 PM
Fidalgo911S's Avatar
VIN will start with 91143XXXX
Engine shroud will be green. Motor is 911/93
Should have alloy front calipers.
Diameter of sway bars should be 20mm front and 18mm rear, IIRC.
Nate
Old 07-24-2010, 04:45 PM
brooklyn ny 11234
Thank you the vin does start 911 410 3xxxx is this correct
Old 07-24-2010, 04:50 PM
A VIN of 91141XXXX is a standard 911. For sure 91143 is the S. 91144 is US Carrera and 91146 is a Euro Carrera.
The standard 911 has a different motor (150hp), and a few other things. Same torque curve though.
Doesn't mean it's not a good car just because it's not an S....condition means a lot.
Nate
Old 07-24-2010, 04:56 PM
brooklyn ny 11234
Ok thx alot now i know
Old 07-24-2010, 04:59 PM
All 74's had fuel injection...
Old 07-24-2010, 07:57 PM
AutoBahned
RWebb's Avatar
Originally Posted by 930 slant nose View Post
... real s ...
I have some bad news. Technically, it is not, and will never be, a real S, in the sense that an "S" is very fast on the top end and is worth a lot of money.
a 2.7L US car that is an 's' will have a green shroud - b/c it is similar to an "E" - a US '74 will have CIS injection, which works, but is not very sporty.
an early (aka, longnose) S will have a red shroud & MFI injection which sucks fuel but is very sporty
the hot item in a 2.7L car would be what is called a Euro Carrera, which is similar to an RS
all of these are terms you can run searches on & then read about them
Paul Frere's 911 book is the best thing to read tho
Now, that said, any 1974 is a very nice sleeper 911. They did not have the motor-killing early smog equipment on them (thermal reactors), have a number of upgrades, and often sell for a a very low price.
If you hate the bumpers you can convert to a the early car look.
or you can save some wt. by eliminating the shocks int he US bumpers and using Euro crush tubes.
Old 07-24-2010, 08:18 PM
brooklyn ny 11234
a friend told me they started making carrera in 1984 is this true
Old 07-25-2010, 10:52 AM
AutoBahned
RWebb's Avatar
depends on what you mean by "carrera"
it used to mean something special as far back as the 356; in 1984 P AG used it to just mean a regular 911
Old 07-25-2010, 12:22 PM
brooklyn ny 11234
the car that im talking has the rear with the wide seperation for european plate is this the way they all are even american model
thx
Old 07-25-2010, 01:49 PM
thx
All '74's, even the US version had the small rear bumperettes with a wide space between them.
Starting with '75 (and on), US cars (only) had much larger rear bumperettes with less space between them.
Old 07-25-2010, 06:20 PM
brooklyn ny 11234
thx for the info
Old 07-25-2010, 06:33 PM
tof2.7's Avatar
if you want all information visit my website :
i will find all information you will need
it's not a forum just a information static website !
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77
Old 07-26-2010, 12:20 AM
