-   -   How can I find my Rear Sway Bar Size? (http://forums.pelicanparts.com/porsche-911-technical-forum/555241-how-can-i-find-my-rear-sway-bar-size.html)
86 911 07-25-2010 07:46 PM
Hi all,
I've decided to change out my sway bar bushing and drop links this week. I took off my rear sway bar and I'm not sure what size bushings to order. The number on the side of the busing says "Weltmeister 027" and there are a total of 2 of these bushings on the rear sway bar. The car is a 1976 although I believe someone upgraded the sway bar because, according to the online catalog, I have the 1978-1989 drop links as well as the 1978-1989 bushing clamps. So.. how do I know which size to order? Thanks! SmileWavy
James Brown 07-25-2010 07:56 PM
measure the diameter with a metric caliper by the bushings. the size of the bar is the size of the bushings to order.
Todd Simpson 07-25-2010 08:39 PM
If you don't have calipers try a few different size open end wrenches.
GrantG 07-25-2010 08:56 PM
That's a good idea, though Harbor Freight sells calipers VERY cheaply (<$10 for digital or $4 for mechanical) and they are useful to have around...
James Brown 07-25-2010 09:02 PM
BRILLIANT! Todd, simple, cheap, always have em.
86 911 07-25-2010 11:16 PM
Thanks for the input guys! I will get a caliper from the local Harbor Freight tomorrow. SmileWavy
