-   -   exterior door handle trigger mechanism - oops (http://forums.pelicanparts.com/porsche-911-technical-forum/55530-exterior-door-handle-trigger-mechanism-oops.html)
jkeyzer 12-31-2001 04:05 PM
My passenger side door trigger mechanism decided to stop functioning yesterday. It turns out that the L shaped piece of poor quality metal that is used to retain the spring and push rod on the backside of the handle has snapped. A quick search in the archives tells me this has happened to more than one person before. Can these pieces be found separately or am I now in search of a new handle just to steal this piece out of?
(Anyone have one they could spare?)
Roland Kunz 01-08-2002 07:08 AM
Hello
Depending on the year ( 5 versions from 1969 to 1995 )
72 was the split using slight other triggers. In 74 the trigger was redesigned again.
No direct spare you only can buy a other outher door handle and swap over.
Some door handles have a broken studs or other misshaps and are not "direct" reusable.
Grüsse
