-   -   VCI Brake Install Question (http://forums.pelicanparts.com/porsche-911-technical-forum/555315-vci-brake-install-question.html)
speedman 07-26-2010 10:53 AM
I have added the spindle spacer to the spindle and I still have the rotor rubbing the lower arm. I have ground some steel away, but I do not want oweaken it too much any suggestions.
TimT 07-26-2010 11:39 AM
Are the struts stock or raised spindle (RSR)
You will have problems even with the spacer if you have RSR struts....
However you can grind quite a bit of the arm away to gain clearance...btdt
speedman 07-27-2010 06:35 AM
they are stock 79's. I will start grinding and raise the suspension up with a floor jack to check for clearence after each grinding. I just don't want to weaking the parts to the point of breaking on the road
KTL 07-31-2010 07:56 PM
I had the same problem on three cars I know of. Don't worry about too much grinding. All three of the cars have been track proven.
MysticLlama 07-31-2010 08:04 PM
Yep, same here, had to clearance the end of the A Arms a bit for Brembo GTP-Ls.
Chuck Moreland 07-31-2010 08:06 PM
The Elephant Racing Decambered Ball Joints will get you clearance. These move the strut and rotor about .2 inches outboard, relative to the control arm.
They are available from our host.
rfuerst911sc 08-01-2010 04:49 AM
You have to grind material away for this " upgrade " ? Not a very well thought out kit is it ? Sorry that just doesn't sound right.
Todd Simpson 08-01-2010 05:41 AM
Yeah, it might seem that way but the VCI parts are nicely made.
The Porsche A arm in comparison is kind of a sloppy steel stamping with extra material on the edge. Take a 1/2mm off or so and you're good to go.
