Oil pressure gauge pegged
Got my '79 SC back from the paint shop and now my oil pressure gauge does not fluctuate with RPM's; stays pegged at the top.
Oil level is good.
No reason why this should be related to having the car painted, but that was when I noticed the issue.
Any ideas on what might be going on? Is the sender most likely toast?
Thanks in advance for any feedback.
1979 911SC
1978 911SC Euro
Instagram: collierbrands
Old 09-08-2009, 04:15 PM
open circuit in the sender wiring. either the wire is off the sender or the sender is bad. ground the wire and see if the gauge drops. the sender is to the right of the engine fan housing, between housing and a/c bracket, sitting on an angle. not the temp sender which is lower and facing to the rear.
206 637 4071
Old 09-08-2009, 04:38 PM
magnumpi's Avatar
This is a timely post ... I just noticed mine is pegged at 5 as well. I've cleaned the heck out of it to no avail. I've read some prior posts where people say you can crimp the female portion of the sensor that plugs in...but the metal is encased in a hard plastic so it's impossible to crimp without serious force that would likely crack the thing? It does come off the male portion quite easily though, so I'm thinking if I could tighten the fit up it would do it but how to....?
Others suggest tapping on the sender with the hopes that it shakes it back to life...this didn't work for me either.
Dan
1980 911 ROW SC Coupe
2014 BMW 328i touring
1999 Porsche 911 C2
Old 09-08-2009, 05:20 PM
Diss Member
Quicksilver's Avatar
The wire often hardens and goes bad at the sender so check thelast few inches of it too.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-08-2009, 05:28 PM
Great info, you guys. Thanks very much for your comments. I'll check it out.
1979 911SC
1978 911SC Euro
Old 09-08-2009, 07:07 PM
I'm here to cause trouble
jimbauman's Avatar
...and if you notice the pressure gauge pegged at the top when you turn the ignition on, but notice it drops to zero when you shift into reverse, you curse yourself for not paying attention to the TWO green/red wires in the wiring harness, and which one switches to green/yellow at the 14 pin connector in the engine compartment.
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 09-08-2009, 07:26 PM
rnln's Avatar
jimbauman ,
can you explain more detail?
Fat butt 911, 1987
Old 09-09-2009, 12:31 AM
jimbauman's Avatar
Sure.... I had to replace one of the the 14-pin connectors that broke - and in doing so failed to note that on the chassis side, there are TWO green/red wires in the harness. These connect to a green/red wire and a green/yellow wire on the engine side of the connector.
One of the green/red wires goes to the pressure guage, the other goes to the backup switch. When you have the connection reversed, the oil pressure sensor circuit is open, and that pegs the gauge. Until, that is, when you hit reverse! Then, you send some voltage thru the sensor, and it fries!
Moral: never assume all wires in any harness have unique colors!
JB
Old 09-09-2009, 02:12 AM
Wow, guys, not my proudest moment, but I've just realized a goof in my opening of the thread:
I hastily wrote oil pressure gauge pegged when I meant oil LEVEL. Granted I didn't have the car when I wrote this, but...
Okay, so Oil Level is pegged...any ideas?
1979 911SC
1978 911SC Euro
Old 09-18-2009, 07:50 AM
Happiest when Tinkering
gsmith660's Avatar
Same thing as the pressure sender pegs on a open circuit
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 09-18-2009, 08:26 AM
Noted. I've just discovered after closer inspection that the wires are fully disconnected from the sender.
Thank again for the help. Much appreciated.
J>
1979 911SC
1978 911SC Euro
Old 09-18-2009, 09:21 AM
Paul Shepherd's Avatar
i am also having problems with my oil pressure gauge pegging at 5.
I have tried earthing the wire and just disconnecting from the sender and it just stays pegged
does this mean a problem with the wire being broken or disconnected
Ocassionally the gauge will work correctley for a while
Old 07-26-2010, 10:20 PM
