3.0 & 3.2 Mufflers ........Interchangeable?
I was wondering if these two engines could accept the same mufflers?
Are the Exhaust manifolds interchangeable?
Old 07-26-2010, 12:56 PM
Oh Haha's Avatar
The muffler from a Carrera will fit an SC(as long as both are 1in/1 out).
The factory muffler for the Carrera has an indent where it attaches to the engine bracket to allow room for the heat exchanger crossover pipe.
The factory SC mufflers do not have this indent so they tend to need some massaging to make them fit correctly.
Aftermarket mufflers such as M+K, Dansk, etc should fit without issue given you order the correct unit for your year 911.
Hope this helps. A search about mufflers will yield more information.
Pacific Blue
Wayne
Old 07-26-2010, 01:32 PM
I have a couple of Mille Miglia mufflers.
One is single outlet, the other dual outlet.
The mounting flange angle is a little different on both.
Can't remember if they were on the 3.0 or 3.2
Old 07-26-2010, 01:34 PM
Oh Haha's Avatar
What are your plans? Do you have an SC or a Carrera?
Pics could help with the ID of the mufflers.
The flange SHOULD be the same for both regardless of the outlet configuration.
Pacific Blue
Wayne
Old 07-26-2010, 01:38 PM
Flanges are identical.
Read haha's post.
I have a gutted Carrera muffler on my SC. Bolted right up.
Can't do an SC on a Carrera, though, without massaging a 'dent' into the top front of the muffler.
Old 07-26-2010, 05:22 PM
The two systems are for sale, but I need to know what they will bolt up to before I sell them.
They came off a 78 911SC but it was either a 3.0 or 3.2 engine.
Old 07-26-2010, 05:27 PM
Oh Haha's Avatar
It the engine is factory installed it is/was a 3.0. If not, what kind of fuel injection does it have?
Pacific Blue
Wayne
Old 07-26-2010, 05:30 PM
It's not the engine size, it's the fact that the stock Carrera with the 3.2 has a heater crossover pipe in front of the muffler. So there is an indentation in the muffler so the pipe will not interfere with the muffler.
The SC has the crossover on top of the engine; an ugly, unsightly, long hose that curls over the top of the fan from R to L. No muffler interference.
So if it's CIS, (SC), no problem.
Old 07-26-2010, 05:31 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
I am not 100% sure about this one... I have information from Ben (M&K) that the inlet on his 1in mufflers are not the same length on the SC and the Carrera ones - and as such not interchangeable...
The info I have is that the length of the inlet pipe is 5.8cm for the SC and 7.4cm for the Carrera
But this info is from Jan 2008 so things could have changed on his mufflers...
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 07-28-2010, 05:30 AM
