-   -   Soft top rear window question- (http://forums.pelicanparts.com/porsche-911-technical-forum/555470-soft-top-rear-window-question.html)
911cabby 07-27-2010 06:25 AM
After 1 month of ownership I just noticed that the rear plastic window half-zips down on my cab- am I suppose to be unzipping (the window that is) before lowering the top?
What the purpose of the feature?
Thanks for your help!
kidrock 07-27-2010 06:37 AM
I believe it is better for the longevity of your top and window to release the top a bit before zipping or unzipping the window.
dfk911sc 07-27-2010 07:32 AM
Always unzip. After i release the tension from the latches unzip and before I latch the top re-zip. This will prolong the life of the window and help prevent creases. Never in the cold. I read somewhere that the additional benefit is ventilation when the sun is beating down on you you could run with the door windows down and the back window open.
bonkers 07-28-2010 10:40 PM
Originally Posted by dfk911sc (Post 5475205)
Always unzip. After i release the tension from the latches unzip and before I latch the top re-zip..
Ditto
