-   -   Correct way to measure wheel spacers? (http://forums.pelicanparts.com/porsche-911-technical-forum/555723-correct-way-measure-wheel-spacers.html)
Tinted911SC 07-28-2010 10:28 AM
I have a set of wheel spacers and the fronts are thinner than the rears.
They were in some H&R boxes and they look alot like the ones on the picture, but I want to be sure what size they are.
Most likely they were used with stock wheels and a turbo body kit made for a 911sc.
Thanks.
JJ 911SC 07-28-2010 10:52 AM
A picture is worth 1000 words...
51/2" - 33/8" = 21/8"
http://forums.pelicanparts.com/uploa...1280343097.jpg
Tinted911SC 07-28-2010 11:08 AM
OK, would that be 2.125" ?
Now to get a measurement in Millimeters........
Jeroen 07-28-2010 01:37 PM
don't see why you'd measure the bell of the rotor as well
or how it's difficult to measure a wheelspacer, but hey...
2.125" x 2.54 = 5.39cm = 53.9mm
Tinted911SC 07-28-2010 02:41 PM
OK, Well Thanks.
JJ 911SC 07-28-2010 04:24 PM
Originally Posted by Jeroen (Post 5477728)
don't see why you'd measure the bell of the rotor as well...
The photo was for something else... A caliper on the spacer alone is the correct way...
Tinted911SC 08-23-2010 12:53 PM
Anyone have any ideas what the size is on these two pairs???
http://forums.pelicanparts.com/uploa...1282596569.jpg
http://forums.pelicanparts.com/uploa...1282596717.jpg
JJ 911SC 08-23-2010 06:04 PM
Looklike...
17/8" and 1"
If they are on the rear (or front), don't worry too much about the difference (left/right)... These car were hand build :D;):D
Tinted911SC 08-24-2010 09:42 AM
So that would be like 25 & 48 mm?
JJ 911SC 08-24-2010 09:50 AM
Yeah 25mm & 48mm is the metric equivalent of 17/8" and 1".
They might not be exactly that because we are doing this from a photo.
