gauge bulb socket replacement
Hello,
After a melt down of my wiring for the dashboard lights I decided to put in the dashlight fuse instalation as described in http://forums.pelicanparts.com/porsche-911-technical-forum/105819-dash-lighting-fuse-installation.html I want to replace all the dashboard light wiring from scratch but have not found out how I can re-use the "bulb sockets (99906320007000)". The wire goes inside but I can not figute out how to get it out and replace it with a new wire.http://forums.pelicanparts.com/uploa...1280510480.jpg Thanks for your assistance! Bruno - Bredene - Belgium - 911sc 05/78 |
Hey Bruno,
Why not just strip the casing and solder onto the existing wires then use shrink tubing to seal it up? That way you don't have to worry about opening and potentially damaging the sockets. J |
Thanks for teh feedback. Sounds like a good alternative. I just wonder how they would do this in a porsche garage, there must be a trick?
| All times are GMT -8. The time now is 06:58 PM. |
