Finally have Bostik "Pure Nickel Special" anti-seize part # NSBT-16N. Contains no copper, good for 2,400 deg F. "For Industrial Use Only"
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
RoninLB,
Help me out please! What is wrong with the copper in copper antisieze or some copper in other anitsieze??? Not good for the O2 sensor?? Thanks. |
Jim...I'm not an expert in this. Nickel is used w/ dis-similar metals. I believe most mech. use copper for O2. Nickel is great for exhaust and head exhaust bolts and nuts. 2,400 deg is pretty good. I would like to find out if Loctite's Graphite 50 anti-seize is better than copper. Loctite's site shows Graphite 50 twice as conductive as Loctite's copper anti-seize. Loctite also has nickel anti-seize. Thanks for keeping this topic going.
