-   -   CIS to Weber conversion question... (http://forums.pelicanparts.com/porsche-911-technical-forum/556441-cis-weber-conversion-question.html)
joeblow 08-01-2010 02:20 PM
Guys,
I am gathering up the last bits to put 40 IDAs on my 2.7 CIS and I cant seem to find in the manuals the throttle bracket part that mounts to the front of the engine near the bell housing area for the throttle linkage. I am trying to figure out if the CIS one will work with the Webers or do I need to start looking for one?
Thanks in advance!
Scott R 08-01-2010 03:23 PM
You don't need the CIS throttle plate. You go from the bell crank though the engine tin to the swivel mounted on the weber intakes.
James Brown 08-01-2010 03:33 PM
If you look at the manifolds, there is a post on the inside forward runner that will hold the bellcrank. that connects the throttle rod up frome the forward engine tin. That's all you need. you can remove the throttle console as it is not needed.
http://forums.pelicanparts.com/uploa...1280705596.jpg
joeblow 08-01-2010 03:33 PM
Scott,
Thanks for your reply. OK I seem to remember this setup now. So I assume I will need a longer linkage arm?
James Brown 08-01-2010 03:35 PM
Nope, same one.
joeblow 08-01-2010 03:38 PM
James,
You and I must have been posting at the same time! Thanks for the pic, OK got it....Just need to hook it up it looks like...
I don't have the manifolds in hand and could not see this in the parts pics....
Thanks!
