SoCal911SC's Avatar
Door Stay Reinforcement question
I've been having a problem with the loud clicking noise from my driver's side door jamb, PLUS it's been taking a lot of force to open the door past each door-stay position (as opposed to the door opening smoothly thru each door-stay position).
So I replaced the small pin where the tounge meets the inside of the body with the 6mm bolt (as recommended on the forum) and that fixed the clicking noise, BUT it's still tough to open the door past each of the 2 door-stay positions.
QUESTION: if I install the Door-Stay Reinforcement kit which includes the new tongue, will that help smoothen out the opening of the door? I do have some of the notorious bending of the outer plate around the 2 bolts in the inside of the door, so it's probably not a bad idea to do it anyways.
Thanks.
Old 04-08-2014, 01:39 PM
take the thing out and squash the two bumps a bit so they pass easier. and keep the arm greased. new ones are the worst.
206 637 4071
Old 04-08-2014, 03:27 PM
SoCal911SC's Avatar
Thanks I'll give that a try. So the new reinforcement kits haven't worked well for people? Or just the replacment tongues aren't good?
Old 04-09-2014, 08:42 AM
gwmac's Avatar
I filed the bumps down some, it helped.
Old 04-09-2014, 09:51 AM
theiceman's Avatar
absolutely do the plates .. i have done hem on about 4 cars now .. i also put in the new door stays .. it is really stiff for the first few weeks but now is great ... not doing the re-enforcement kit and just puting new stays in will probably rip the door they are so freakin stiff..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-09-2014, 09:59 AM
Ferrino's Avatar
Agreed, putting in new stays and not grinding down the bumps will make things significantly worse.
Old 04-09-2014, 10:02 AM
SoCal911SC's Avatar
Thanks all, just placed order for the Door Stay Kit and Reinforcement Kit to go with it. Should I file down the new door stays a little before installing them? Or just let them loosen up naturally?
May have some other questions when it comes time for install, but I appreciate the info.
Matt
Old 04-09-2014, 10:43 AM
Uncle Enzo's Avatar
Here is my fix. I had no success with the kit as my door was too far gone.
1976 911S
MidYear Fever is alive and well.
Old 04-09-2014, 11:00 AM
SoCal911SC's Avatar
I like it! It's kinda Outlaw style
Old 04-09-2014, 11:06 AM
Uncle Enzo's Avatar
If you want a repair kit and new check, ill sell you mine for peanuts.
1976 911S
Old 04-09-2014, 12:05 PM
Ferrino's Avatar
Matt
I suggest you install the stays and see what it's like. In my case it was very stiff - such that you think the mechanism has seized. I ground mine down and am probably going to do a little more, even with a fair amount of grease in there. My car is in restoration mode though - people who have replaced them often comment that they ease up after some weeks of use.
Old 04-09-2014, 01:19 PM
New door stay mechanism.......
These are the door stay mechanism that I am planning to install in my car. But they are so stiff or hard, I couldn't make it slide or move even with several blows by a large rubber mallet. They felt like welded.
Any advise is much appreciated. Thanks.
Tony
Old 04-09-2014, 03:46 PM
You absolutely should consider doing a major trimming of the nylon stops in both old or new door stays. And, you do need to install a stiffening plate on the existing door jamb.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 04-09-2014, 04:08 PM
Ferrino's Avatar
Why would you want to trim the nylon stops?
Old 04-09-2014, 04:11 PM
Just like what JW said.........
I tested the new door stay mechanism by using my 20-Ton hydraulic press just to slide the arm but the resistance was so great it got to break the door first to get this thing to move a bit. So I decided to follow JW's by grinding the high spots on the sliding arm. It took a couple of trial and error (grinding) to get the right thickness for the arm to slide with some acceptable resistance. Will test with the door and find out if I need to grind some more or not.
Tony
Old 04-09-2014, 05:19 PM
I stand corrected. The stops are actually an elastomer, and not nylon. The "fix" on the door checks is to disassemble the check and, using a razor blade, slice material off the stops which thins them down so that the metal detent on the strap has "less" of an obstacle to overcome when opening the door. Such was the construction of the door straps on the 993; and, I have assumed that the design has not really changed, since the taughtness of the door stays actually fatigues the tack welds that attach the stay pin to to the front fender post. I've had both stays cause a failure of those tack welds on my 993.
Ernie
Old 04-09-2014, 06:32 PM
Bill Douglas's Avatar
I did my drivers door last weekend. I used the old stay but put the kit in. It works well. For some reason it was a bit stiff but I just ignored the problem and now it's loosened up to being OK.
Old 04-09-2014, 07:07 PM
wacko's Avatar
PM sent
Old 04-09-2014, 07:44 PM
SoCal911SC's Avatar
So this has me a littlep confused. I have a new stay mechanism arriving today from PP, and you're saying to trim down the bumps on the brand new part....possibly requiring disassembly? And if the slider is nearly impossible to move by hand (or rubber mallet), what's the best way to slide the tongue out to grind down the other bump?
Old 04-10-2014, 08:17 AM
theiceman's Avatar
yup ... i thought i was gonna bust the door they were so stiff even with the re-enforcement kit ,, but glad i didnt mess with it because after a few weeks it is perfect..
Old 04-10-2014, 12:14 PM
