hub extension dilemna and front wheel bearing
I was inspecting my front wheels due to a rumble wobble.
when i removed the right front wheel hub the outer bearing a timken lm 11949 was bad. It actually has a flat spot on the outer cage. Should i use loctite when reconnecting the 5 13mm hub bolts hub to the extension?
1975 911S Targa Silver Anniversary Edition Last edited by 47silver; 08-03-2010 at 12:02 PM.. Reason: spelling |
