-   -   problem engine on 964 (http://forums.pelicanparts.com/porsche-911-technical-forum/556988-problem-engine-964-a.html)
jm993rs 08-04-2010 03:30 PM
hellow ......
today my 964 when I'm on the road repently STOP and when give to the car more key the engine no start . I telefone to the work and one truck for arrived to my house and 15 minunts later the engine start perfectly.
30 mimutes later the engine stop another time, and just in the moment I give key and no start. And 15 minutes later give key to the engine and start perfect. I arrived to my house perfect and I have the question ¿ whats the problem ? the DME relay ?????? the pump of benzin ??????
thankssssss:confused::confused::confused::confused ::confused::confused:
KNS 08-04-2010 05:05 PM
The DME is good place to start. You might try the 964/993 forum here on Pelican Parts for a little more help. Rennlist.com also has an active 964 forum that may be able to answer your questions.
Jerry1 08-04-2010 09:22 PM
Don't forget the fuel filter.
tcar 08-04-2010 10:07 PM
Yes,
Classic fuel filter clogged symtoms...
