door locks
Hello, what is the consensus on winter door lock lubrication and protection. This is for a 88 911 with auto locks. All comments greatly appreciated.
I just put some thin oil on the key now and then to keep the lock moving.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
White litium in a spray can, they usually come with a tube that presses into the button nozzle and fits inside the key slot. I use the same stuff on the hinges and latch.
I use a graphite lubricant. It comes in a spray can and goes in as a liquid with the graphite in suspension. I think the liquid evaporates and the graphite sticks around. It seems to work well in Vermont and it gets pretty cold up here.
Charlie
Charlie '72 911T |
Super Moderator
Use graphite. Oil lubes will attract dirt and gum the works eventually
