LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
lateapex911's Avatar
Top notch!! Been there, done that, but on a coupe, and I bought the headliner...so i cheated. your seams are great!1
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-13-2013, 10:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #261 (permalink)
My dash looks great...
Until you turn it upside down. I don't remember it missing studs, but in fact it is missing a couple...in fact nine studs are missing.
Seven here...
And two here...
And I think these are the missing clips/studs that go here, but I can't see how to reattach them. They would have been installed on the steel dash before it was covered.
So for the seven missing studs on the backside, I turned a some bolts down to exactly fit the holes.
It is a tight fit. With some JB weld behind and on top, they should stay snug
The two over the instrument cluster have square holes. I need to approach these differently. Nothing to wedge them against. Elevator bolts to the rescue. If you have to ask, you can't afford the answer.
I trimmed these up to be rectangular and slightly longer than the square hole so that I could wedge them into the square hole, center them and then rotate them 45 degrees so that the corners catch the flat sides of the square holes. Trial fit looked good, so I removed them and filled the pocket with JB weld and reinserted the bolts, rotated and added some JB weld frosting to the top. These won't move.
Restudded
I erred on the side of longer studs, so when I next trial fit the dash...I may need to shorten the studs. I can do that. Tough to go the other direction. Finishing up the rear B pillar trim on the drivers side
I am getting burnt on the interior. I need to finish the door jams this weekend and start to work on the targa bar...I may need help remembering the process. It has been to long since I took it apart. I have sourced my soft window. Rear seats need to go back in as does the interior rear trim and upholstery.
Speedo
Old 05-14-2013, 06:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #262 (permalink)
How not to repair/replace door mirrors....or well I guess they did work for a while
I guess the cars came over with one mirror as standard issue and as an option you could order a passenger side mirror. I like being able to see behind me or along side, so I sourced a second mirror for the passenger side. Housing looked good, mirror was crap.
The drivers side didn't look much better. New repops are $75-100. I called around to glass shops and the first shop wanted $40 to cut a new mirror...hmm at that price, the repop might be the way to go. I called a second shop and the price was $7.50...note to self, stay away from first shop. Took a mirror into the shop so they could both measure and confirm pricing. Better news, yes the shop could cut the exact size...price change though $6.50 per mirror So I paid in advance and waited three days (same amount of time I would have had to wait if I had ordered repops).
Picked up the mirror glass today and as promised, both pieces were cut and the otherwise sharp edges nicely beveled. Now to get the glass out of the first one. Looks to have been glued or silicone in place and as I didn't want to destroy the rim or surround by prying it out...I figured I would break the glass and remove the smaller pieces.
But wait...there is another layer of glass under this one
Yer kidding me. The replacement glass was glued over the top of the old glass? No way.
What a cheeseball repair. I really hope that a shop didn't do this. Makes about as much sense as glueing another windshield over your existing when it cracks due to a rock chip
Old 05-17-2013, 05:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #263 (permalink)
There is a better (right) way
Not that all repairs need to be done right...what am I thinking.
The correct way to take these apart is to work an exacto knife blade around the circumference of the mirror between the metal edge and the plastic surround. Being patient and careful, the plastic surround will pop out releasing the mirror.
There is a thin rubber gasket behind the mirror that seperates it from the metal of the mirror that needs to be glued in place
And the new mirror was missing an attachment bolt that is slotted. I'll just slot one myself
Done
Gasket glued in
and plastic surround with new glass installed. Rinse and repeat.
The before mirrors, attractive aren't they?
And the after mirrors
Gratuitous art shot...couldn't help myself
Speedo
Old 05-17-2013, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #264 (permalink)
Lars you are fearless.....
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 05-17-2013, 08:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #265 (permalink)
Mirror location
So my mirror holes were welded up prior to paint. I believe the two different size Durants (swb to lwb) have the same size bases and gaskets. I know the drivers and passenger mirrors were in different locations. Would someone with Durant mirror be so kind as to snap a picture of their driver's mirror, and measure down from the door top to the center of the mirror 's horizontal axis, and the same fro a relative forward point as the door starts to curve down...measure back from that point on the door to the front of the base. I would greatly appreciate it. I know the passenger mirror is moved further back...but I think if I have the vertical location down from the door top edge...I can adjust the horizontal position by moving it to where I can see it through the passenger vent window. Unless of course, someone has the exact measurement
Speedo
Old 05-18-2013, 03:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #266 (permalink)
Porsche Nut
merbesfield's Avatar
Speedo
Lars, I'm not positive but I think the mirrors are different bolt patterns. My 66 mirror holes DO NOT match up to those on my 68 large head Durrant mirror. Kenik is sending me an early mirror and once I get it I can give you comparison if no one has answered your question by then. Thanks
Old 05-19-2013, 10:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #267 (permalink)
PMB Performance
Eric_Shea's Avatar
You should be able to look through the door shell and see the mounts. Possibly even take a pick or a drift and mark the location. Then go topside and redrill.
Old 05-19-2013, 12:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #268 (permalink)
Thanks Eric...
May not be so easy as these were SC doors and both the mounting holes and positions for those big flag mirrors are not the same. Someone measuring relative position off their 70-71 door would help the most.
Anyone able to go outside and measure off their car?
Speedo
Old 05-19-2013, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #269 (permalink)
Here are a few photos from my '71.
Hope this is of use. Love the project.
Chet
Chet Dawes
1971 Porsche 911T Coupe
1974 Porsche 914 2.0L
2004 BMW 330i ZHP Sedan
2008 BMW X5 4.8i Sport
Old 05-19-2013, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #270 (permalink)
And my mirror glass really could use a replacement so I'm very pleased to see an example of how this is done. Thanks!
Chet Dawes
Old 05-19-2013, 05:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #271 (permalink)
Scored some goodies yesterday
I needed to replace my rear side panels with the correct panels to use with retractor belts...local source had some I wanted to look at. Another local source had some parts that were left over from his 67 S SWT and I figured I would circle back around and see what he had. It would also give me a chance to take some pics of his almost completed car to see how things look in final assembly. It was a road trip of sorts...but paid off handsomely. Got stuck in late Friday afternoon Denver traffic and the speed was slow, but my spirits were high. I need to go unload the truck and shoot some pics...
Speedo
Old 05-25-2013, 07:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #272 (permalink)
gearhead
Unload the truck? Sounds like more than seat belt mounts followed you home.
BTW, took a look at my door handles. I'm missing the parts that you need. Mine are broken and gone, so we couldn't use them for a mold. Sorry.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-25-2013, 09:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #273 (permalink)
Well it wasn't a truckload....
But it was loot...
Needed these because I'm adding 3 pt retractors
And mine look like this
PO at some point installed speakers and I had the option of recovering mine and creating a slot, or finding the correct panels with good upholstery and a slot already cut
The seals may be useable, maybe not...never installed, but they might have been accidently cut...we'll see. These are what I needed...
SWT base trim. Phew, I wasn't sure I would ever find these, and nobody makes them any more. I'm getting closer. Targa bar cleaned up nicely
But I have some studs to replace
Old 05-25-2013, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #274 (permalink)
Little disappointment
The recessed stamping where the retractors will mount
Plugged from the back side
Test fit
May as well trial fit the new slotted panels
Bummer...makes the panel look pregnant. I'm guessing that I will have to reuse my old panels and use the small retractor housing used on the 72-73 targas, as this just isn't going to float
One step forward and two steps back. Ok, another road trip to swap panels and grab some of the correct housings. Meanwhile I can get the retractors dialed in. There is a locator pin on the backside to orient the mechanism correctly. This needs to be drilled
On to the outer mirrors. While at the softies shop yesterday, I did a tracing of the mirror position
This will help me dial in the approximate location to drill.
Old 05-25-2013, 12:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #275 (permalink)
Softie 67 S pics
This car was/is a 10.5 out of 10. Some pics of the detail....
Eye candy...no less. I aspire to that level of finish...sort of
Speedo
Old 05-25-2013, 08:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #276 (permalink)
Finished the mirror and the door top trim
Got my holes centered
Drilled and done
Top trim installed
Wasn't looking forward to this...front underside of roll bar needs upholstery before the inside upholstery can be installed
Need to cut it from the old nasty piece
Trial fit...getting faster at this
Backside
And done
Dash with new studs installed and secured with vent surrounds
Old 05-26-2013, 06:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #277 (permalink)
Jonesing to get the rear window done...
Curtisaa is helping me with psychological and technical help. I hate having to undo something that I rushed to do only to find out that the next procedure is going to be really difficult...because I rushed to complete the previous step. The targa bar needs to be repaired...ground away the old studs
Created the new studs
Test fit...looks good
And welded up
Ready to go
Now that I got the targa cover ready, this goes on underneath first
Preparing the rear deck sound insulation
More tomorrow...
Old 05-26-2013, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #278 (permalink)
Porsche Nut
Looking good Lars. I passed on a 68SWT a couple of years ago. I had always kicked myself for that, but seeing all the work you are doing I am not saw angry at myself .
Old 05-26-2013, 06:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #279 (permalink)
I could use a picture...a contorted picture
Of looking up at the back of the targa bar...while laying in the back seat. I need this to figure out how to trim my targa bar interior upholstery to accommodate the SWT latches. Or on the other hand if someone actually has this upholstery out of the car, that would be a much easier picture to take. Here is what mine looks like, and I need to trim to be able to access these.
Instead of just hacking away at them, it would be nice to see what the factory did to differentiate the SWT from the hard window.
On a different note...
Treating myself to some woodie choices, VDM, Nardie or Momo.
I'm liking the Nardie look...smaller and simpler. Hey, car's got a wood shifter, they can be pals
This no, car hasn't been THAT much of a pain...just a classic OSFTSB
Happy Memorial Day guys
Speedo
Old 05-27-2013, 12:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #280 (permalink)
