LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
Reiver
Reiver's Avatar
Looking very good, I really enjoy your ingenuity and thought process as it translates to fabrication.
I like that last wheel pictured, beautiful wood and detail...they only look correct on that period of P cars.
Old 05-27-2013, 12:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #281 (permalink)
rokemester's Avatar
My 87 Targa will be in the shop for another month or so just when the driving season in Northeast Ohio is kicking in. This fantastic thread reminds me to be patient. What a creative and skilled craftsman you are. Inspiring! Subscribed. Like someone said early, can't wait to see the Gemini Blue Targa on the road and humming with the 2.2 liter.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 05-27-2013, 08:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #282 (permalink)
howard freeman's Avatar
subed
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 05-28-2013, 08:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #283 (permalink)
Sorting out some details
Rear shelf, crescent trim at the edge of the rear shelf, and the side trim all need some clarification as to whether the hard window stuff will work with the soft window. My new front targa windshield-top gasket (thanks Dan at CarsInc) and 72 belt retractor covers (thanks slcarr) arrived today. Yves (freezing14) has also helped out with an installation procedure. With a bit of luck, this will go together this weekend. I am still needing a good understanding as to how the targa bar headliner is clearanced for the latches. Hoping some pics will surface. There are three different SWT headliners (mine is the latest) and I don't want to screw up modifying mine. I called Stoddard today and the SWT headliner stuff... very NLA. So I will have one chance to modify mine correctly.
Speedo
Old 05-29-2013, 06:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #284 (permalink)
Going to be a busy weekend...
These arrived...yeehaw
72-73 regulator covers. They go here.
That means these need to be recovered to eliminate the speaker holes
I need to strip the outer upholstery and see what the cardboard panels look like behind
Very attractive...
So these need to be re-created. I strip off the existing speaker-perforated vinyl
These are in great shape...I will offer them up after I make my blanks.
Question...why is there a seam here
Speedo
Old 05-31-2013, 07:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #285 (permalink)
I create problems...unecessarily
I didn't look closely at the regulator housings when I got them...but they will not trim correctly with the 70-71 side panels
Either these are from a coupe which has a shaped cover for the area behind this, or the 72-73 targas have different side panels. I could hack these up to get them to work...or figure out a plan B that gets along without them. I need to make the side panels anyway so I will hit them first. Cutting the vinyl and the foam
Marking for the pleats
Sewed up
I used some extra material from some old mis-cut door panels and my electric shear
All trimmed to fit
First one done and fitment looks great
How do I deal with covering these up...
The recess in the wall is not deep enough for the panel to lay flat, nor is it flat enough to just mount the regulator on the outside such that it is visible. Hmmm,
Need to think this one through. I thought about hammering the recess deeper, and also maybe hammering it back flat so that I could mount it on the outside. Both seem to be amateurish options. I have a better idea...
Old 06-01-2013, 05:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #286 (permalink)
Maybe I can use the panel..
And no regulator cover. I measure the belt movement
And try to scribe where the belt wants to be..
I measured for the bezel and reinstalled
I now need to notch the interior trim for the handles
And renew the vent screen...these are acceptable...but look like crap.
I need to figure out how to notch the interior trim for the latches
I am going to need some help here...
Old 06-01-2013, 09:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #287 (permalink)
I feel like a dog getting ready to lie down...
....and he circles the spot three times before lying down. On another thread I learned that there are actually four different types or targa bar headliners. Three soft window and at least one hard window. The good news is that I don't need to be troubled by having to pick and chose one of the soft versions...bad news is that I only have a hard version. I will have one try to get this right
So like the adage measure four times, cut once...I installed and uninstalled this thing repeatedly to get my measurements correct...where to start?
Well as I may be able to re-use the vinyl, I should scalp this guy first...carefully
Measure and re-measure then re-re-measure
Steady hand to make the cuts
I am going to do one side first. If I screw up, then...maybe I can fix it, learn from my mistake and not botch the other side...I feel like this is the point of no return, and I understand why high-end upholsterers commands the big bucks
I check the fit...hey this is going to work
With the latch in place
With renewed confidence...just kidding.... I attack the other side
One more thing needs to be checked....
Old 06-02-2013, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #288 (permalink)
Actually two more...
The operation of the handles in the cutouts. Phew...passed
Sacrificed. I'm really curious how these aluminum/foam shapes were manufactured by Porsche
So now I need to develop a plan to recover this baby. I think I will trim out the side pieces and then slot the original vinyl and tighten it at the front of the cutout.
The old vinyl is in good shape...but hard and inflexible. I'll use the advantage of mother nature at 8100 ft to warm it up
It loosened up enough to become somewhat pliable. I trimmed the cutouts and got ready for a trial refit
So far so good
I am very ok with how this came out
One more unexpected hurdle...hurdled.
I am just going to prime the bows...they will be inside the vinyl from here on, no need to paint them
I need to figure out these before I install the soft window. They cannot be installed after the headliner. And the headliner is basically done. I have a hole punch...but it likes paper not vinyl
Anyway, latch receivers are painted, bows are primed...I am close to the soft window install
Old 06-02-2013, 05:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #289 (permalink)
Hi All, I have read all the pages and I am in "What" "Why not" and "How", of your work Mr. Speedo. The first one is, what, you can actually fix that, you have an incredible talent, secondly, why not, refers to, why are you not my neighbour (Hahaha!!) and lastly, how come you got all the talent and left none for me, just kidding but you do have incredible talents, so Congratulations on everything !! BTW, if you want to make more room in your garage, I have space
Yves
Montreal
Old 06-02-2013, 05:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #290 (permalink)
Tandy leather carries leather punches in different sizes:
Tandy Leather Factory - Craftool Round Drive Punches
Old 06-04-2013, 04:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #291 (permalink)
Punches...thanks for the lead
Not sure how many cowboy belts and saddles I plan on working on...but I now have some cool punches. I will start to work on these vents tomorrow. Not planning on going into production
Speedo
Old 06-04-2013, 07:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #292 (permalink)
Start with the vents..
Time to knock them out
Hold it down and make some holes...168 holes per side to be precise, or a total of 336 holes to punch. And while I used the old covers as a template...slippage of the hands during the process will give me the opportunity to start over
Before and after...huge difference
The frames deserve a refurbish before receiving new vinyl
I'll get them cleaned up, primed and painted before the re-installation of the new vinyl vents.
Old 06-05-2013, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #293 (permalink)
Ah the crescent...
At the rear edge of the shelf cover, and under-lapping the cover, lays (not sure how this one could actually lay)a piece of plastic, trimmed in vinyl. It is secured to the shelf cover and butts up against the rear window. I am told it is the same part number for both the hard and soft window. No way to check until some work is done on this one
It is in really bad shape. Like a dried up snake that got run over a few times
As I don't have much experience flattening snakes (or plastic for that matter),
I approach it logically but with a chunk of trepidation
As mine is also conveniently broken at the center (weak spot) I will massage the halves first
And then work the two sides together. Major improvement with slowly applying heat and working the soft (very hot) plastic with gloves
Nice warped gap in the center to close.
Things ended up pretty straight. I will need to glass the two sides together, but waaay better than when I started
This, when returned to a single piece will get fitted to the rear shelf, re-upholstered and affixed to the shelf cover. So glad this car is going together soooo quickly...uugh.
Old 06-05-2013, 06:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #294 (permalink)
67targa's Avatar
Send a message via Yahoo to 67targa
Very inspirational. After going over your interior I decided to tackle mine rather than doing to a shop. I have a 67 softie and wish I could have helped with the inner targa bar piece that you notched, but I just found the thread while researching for the answer to another restoration question. I think you are doing a fine job and although many consider softies loud, leaky etc, I consider them an important part the Porsche story. I have a question regarding your dash. What thickness of foam did you use on the decking? Also on the rear quarter panels it looks like you used a plastic panel (ABS) as the base material plus 1/8" foam, is that correct?
Thx for the detail photography on this thread ,,it helps.
67' tangerine targa
Old 06-11-2013, 02:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #295 (permalink)
And more...
The side vents went together well...kind of artsy
And installed
My helpers. Don't know what I would do without these guys. They have truly found their calling
Couldn't have done it without you...
Back to the crescent...more work to get it ready to be recovered. I fiberglassed the joint for strength
Don't know what happened here...
But it needs to be massaged to look like this
So it can integrate with the side top cover. Onward
Old 06-18-2013, 06:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #296 (permalink)
The dreaded rear shelf...
I was going to re-use this till Dave Brown (targa top expert known world over) came up to pick up my top and commented on my work so far...and suggested that using my old shelf would really be a low point in my resto. I pulled it all apart
He was right, as soon as I removed the vinyl, it fell apart. The duct tape is not for looks...
I have new waterproof cardboard and sew able foam
My pattern
The vinyl is cut....I need to spend some more time sewing in pleats
Sort of good news... I found out from Dave Brown that my targa top (although it looked great) had some structural shortcomings. So I bought another core targa top off of the 912 registry for parts. I didn't realize that there were two variations of targa tops...67 up until 69 1/2 and then 69 1/2 -infinity. Well turns out the parts top I received was an early top with an aluminum frame vs the later magnesium frame. We are going to steal parts from the later top to rebuild the early top which would more likely have been found on a softie. A bit more work...but apparently the earlier tops also fit the windshield A pillar and windows better. I'm psyched.
Old 06-18-2013, 06:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #297 (permalink)
Porsche Nut
merbesfield's Avatar
Making good progress Lars. Thanks for posting pics along the way.
Old 06-19-2013, 07:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #298 (permalink)
67targa's Avatar
Hello Lars, thank for the dash information. Looking at your rear panel you stated that you have new water proof cardboard. What and where can I buy It?
67' tangerine targa
Old 06-19-2013, 01:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #299 (permalink)
mikeferg75's Avatar
Go Lars go!!
1975 Carrera Coupe #391
1980 924 11k orig miles
1974 914 2.0 LE Creamsicle
1979 Dodge Lil Red Express
2015 Wrangler Unlimited, and a bunch of bicycles.
Old 06-20-2013, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #300 (permalink)
