Power Seat Bushing question
If there is a thread already please share. I installed the new bushings into the worm drive for the rail. How tight do the bolts need to be holding the washers in place. Tight enough to hold, not so tight they don't crunch the ball bearing housing? One of them came loose after installing so I was just curious. The new bushings sure get read of the loose seat I've suffered from for years.
Thank you! Last edited by Cmdykstra; 10-20-2023 at 07:38 AM.. |
