KoenigsTiger's Avatar
Unhappy Safe to use this Oil Line?
Hey Everyone,
I did the compressed air & torch fix one this. There was a pretty nice crimp here. I did the best I could, with out using too much heat. Do you figure its ok to use with this line/ stressed spot?
Thanks,
Gene
Old 08-07-2010, 10:08 AM
Danny_Ocean's Avatar
Eh. Looks like one on my car. Not sure I'd use it if I had a choice, though.
Old 08-07-2010, 10:12 AM
Yeah, I may gett a better one locally... I am just debating if I should?
Thanks Danny!
Old 08-07-2010, 06:53 PM
I'm no expert, just my observations but there have been lines with more severe denting that people have run on their cars with no noticeable flow problems (non-track cars.) However, what would concern me is the look of the dent in the center of the photo. There appears to be a sharp crease running from the bottom left of the dent toward the deep half-moon shaped mark. That could be a weak point/crack that might spring a leak--it's hard to tell from the picture. If the line was mine, my concerns would be about possible leaks rather than flow and if in doubt, I'd replace.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-07-2010, 07:08 PM
You that part just be cut out and a new section of pipe brazed in or does that not work?
Old 08-07-2010, 07:34 PM
Yep, thats what worries me. What it looks like on the inside, the crease... The flow will be fine, but the crease. I'll try to get a better used line...
I have seen guys solder in repar pieces, but I am not sure how secure that would be...
Thanks a lot guys!
Gene
Old 08-07-2010, 07:39 PM
rnln's Avatar
I have seen more than one cars which have worse damage line driving for years.
Fat butt 911, 1987
Old 08-08-2010, 12:43 AM
Hmmm, decisions decisions...
Old 08-08-2010, 07:44 AM
safe's Avatar
That denting wouldn't worry me at all.
Magnus
Old 08-08-2010, 02:53 PM
RETIRED
Joe Bob's Avatar
Seen worse.....
2012 ML350 3.0 Turbo Diesel
Old 08-08-2010, 04:53 PM
No problem, don't worry about it. Scavenge lines are very low pressure.
-Andy
Old 08-08-2010, 07:06 PM
Thanks a lot guys! I'll run with it!
Old 08-08-2010, 08:47 PM
