Location: From Hawaii, currently living in the Columbia, SC area.
When I was in Hawaii, a well known Porsche Mechanic on the island of Oahu who did some work on my SC told me that syntetics were the way to go and he used only synthetic in his own 930. I use Castrol 20/50 now partly because I like changing oil every 2500-3000 miles and doing so frequently with synthetic makes no sense.
Anyway, I have two questions as I am about to store my car as I go off to my next duty station overseas in Korea. 1. Since my car will likely be started maybe one a month for the next 2-3 years, would it be better to store it with synthetic oil in the engine? 2. Once a motor has used synthetic oil, would it be wise to go back to conventional oils or should I remain with synthetic oils for the duration? If synthetics are the way to go, I saw another post that Royal Purple, Swepco and Red Line were good to go with a good amount of the anti wear stuff already in it. Has anyone read anything on the Mobil1 15-50 oil? Okay that's the thrd question... Any advice on this will be appreciated. Fred Ramirez Fort Leavenworth, KS |
Make Bruins Great Again
Fred, there are already a thousand posts about oil and everyone has a different opinion. Take some time and search. For starters, search for: ultimate motor oil.
As far as storage for 2-3 years is concerned, when the car is started it needs to be brought up to full operating temp and run for at least 15 minutes or so. Then, no matter what the mileage, change oil and filter once a year. p.s. Thank you for your service to this country! Be safe and God bless.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Fred,
With today's oil, the dino/synthetic argument is mostly academic. More important is ensuring that the oil you use has enough of the antiwear additives and decent detergent package to ensure you do not see premature wear on your cams and other parts subject to high pressures. Sadly, oil is no longer just oil. Due to Government and car maker pressures, the newer oils are now being formulated to not only lubricate your engine but also be "energy efficient", protect catalytic converters and allow for extended oil change intervals. These changes have been made at the expense of some lubrication needs of older engine that result in reduced engine longetivity. You can read the Ultimate Motor Oil Thread or Why we hate CJ4/SM oils to get the full story. Cliff notes go like this: Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 11-21-2010 at 03:19 PM.. |
Mobil 1 15/50 Extended Performance is not good. Mobil One 15/50 High Performance is OK. Mobil One V Twin motorcycle oil is better.
Joe / Harry,
Thanks both for the responses. As I looked at the other threads, ZDDP seems to be a topic of much discussion. From the list, there were several 15w / 40 motor oils listed. I've seen some of them on the shelves and if I recall correctly, they are recommended for diesel motors. Anyway, I went into my garage to look at a container of castrol 15w/40 and it indeed had ZDDP. It was however an oil recommended for diesel motors. I've heard of good things about Shell Rotella. I think they carry 15W 40 in a synthetic formula. I'll check this week. If they do, I'll go with the Shell, add a shot of Lucas stabilizer and call it a day. Daniel, thanks for the heads up on the Mobil 1 High Perf. Thanks again for the response. Fred |
Hi,
Steve Weiner has seen more stressed 911 engines apart than most of here due to his Race Shop. Here are some of his recent (4/23/2010) thoughts on response to the Mobil 1 issue: Quote:
Shell Rotella-T 15W-40 is a mineral oil.
Shell Rotella 5W-40 is a synthetic, ....and they are dinking with the formulas as they offer a T6 variant and others...confusing. Caveat Emptor.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
http://www.castrol.com/castrol/datasheetsearch.do Be careful when you look at them and check the dates and which API Specs the report is based. Shell has some good products. Again, be careful.
Pre Registered
I am a hard core mobile one guy, UNTIL, yep you got it. I have mobile 1 in my mbz amg, 911, f350, wifes volvo, kids corrolla, and my outlaw oval track car, we have been running left over supply from a couple years ago, ran out this spring used 20/50 like always then started noticing car was running hotter tons of blow by, took it apart sludge in pan, broke a roller lifer, motor guy says yep gotta have the additives or the needle bearings go bad, he tells me this after we replaced the lifters and it took out the main bearing and broke a main cap. he said he sees the exact same issue with all motors that do not have true racing oil.
I went brad penn in the outlaw, probably gonna put itin my 911, not sure what to do with my amg, o and gonna put brad penn in the f350, after 25 years and gallons and gallons i am done with them, Kevin |
Just buy a good 20/50 and add some ZDDP.
ZDDPlus Oil Additive - ZDDP for Classic Cars & Trucks ![]() Wait until it goes on sale if you can.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Fred; please go back and do some more reading. ZDDP is not the only issue. Many oil companies have been screwing around with the ZDDP and the additive package. I used Castrol GTX 20W50 but after 5k miles it ran out like water. Not so for Brad Penn. I know that there are other good oils beside Brad but you have to look at the whole picture. Right now you won't have that many miles between changes but you still need a quality additive package in your oil. Do your homework.
