Yep, I've done that!
joeblow's Avatar
Raush & Spiegel Oil Return Tubes - Reusable?
Guys I am cleaning up one of my engines on an engine stand and thought that I could do the sheet metal mod to increase cooling around the cylinders. Of course to do that I have to remove the oil return tubes. I have the Aluminum ones from R&S (Pelican). Do you guys know if they can be collapsed and re-extended again or am I going to open up myself for leaks? I do intend to change the O-rings even though they are very fresh.
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 08-08-2010, 01:12 PM
Checked out
McLovin's Avatar
All the collapsable return tubes can be reused. New orings probably aren't a bad idea, though.
Old 08-08-2010, 01:52 PM
joeblow's Avatar
I did not put these it so I am not sure they are the same as the factory steel ones, do the have o-rings in the center between the two halves as well? Are they available? I will be changing the factory o-rings on the outsides of the tubes.
Old 08-08-2010, 02:38 PM
The outer end seals (@ case and cam tower) are the same as O.E. p/n: 999.707.112.40 available from Pelican. The inner seals are - (dash) 020 Viton o-rings, available from anyone who specializes in o-rings or from McMaster.
1986 3.2 Carrera
Old 08-08-2010, 03:13 PM
