D911SC's Avatar
Black 'stuff' where fuel lines go through body
In cleaning up under my car I have come across a black tar like coating where the fuel lines and brake line go though the body to the rear. With a bit of scrubbing and grease remover it is coming off. I have seen some other pics by searching this site and it appears to be a factory coating.
Can anyone tell me if this is the case and what its purpose is? I am guessing it's to provide a barrier of some sort.
The real question is that after I have cleaned it up what would be the right product to re-apply?
Here's a borrowed pic - it shows it better than the one I took. You can see that it is also on the brake line fitting which is exactly the same as my car.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 08-08-2010, 06:04 PM
steely's Avatar
If it's the same stuff they use on top of the strut towers, it is tar - mainly to block water. I think I read where you can use a regular sealant (silicone for example).
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-08-2010, 08:15 PM
