-   -   Tire Size - Clarification/Advice for running 4-16x7s (http://forums.pelicanparts.com/porsche-911-technical-forum/557901-tire-size-clarification-advice-running-4-16x7s.html)
pplkook 08-09-2010 03:00 PM
All
I am going to run 7x16 on all four corners on my 84 carrera cab. Ideally I would love a set of 8s, but that is low on the list for now. I am going to run a 1 inch spacer on the rear.
I have searched the forum and ran across a few posts where people did this. I saw folks with the 205/55 and 225/50 setup as if it was stock 6/7. I also saw someone who was running the 225/50 on all four corners.
I know that tire manufacture comes into play, I think I am setting in on the Dunlop Direzza Sport Z1 Star Spec. This car is only a street car, does not do track or DE. Right now it is set to stock US height, and I don't want to get into rolling fenders.
What tire size would you recommend? I like the appeal of running the same size on all four corners.
Jack
Bill Verburg 08-09-2010 03:17 PM
Originally Posted by pplkook (Post 5497631)
All
Jack
I'd use 205/55 & 225/50
pplkook 08-09-2010 04:51 PM
Thanks for the input...
-Jack
911st 08-09-2010 05:06 PM
I agree with Bill.
Some times it can be a little bit of a chalange to fit a 225's on a 7" rim up front unless you have a rolled fender and have maxed your neg camber.
Other than that there is no reasion you could not run all 225's on a street car.
Porsche ran a square set up on there street cars for years. The biggest advantage is you would then be able to rotate your tires front to rear for a longer tire life.
As to performance, modern 911's have mostly understeer dialed in as much as it possable so having a 225 up front will help with understear a little. It might also reduce stopping distances a little.
However, where the 911 needs more tire is in the rear if one wants to increase performance potental.
I had the Star Specs and loved them. Great tire.
