Mark S
Opinion on 901 syncro please.
Clutch problem had to drive 20 miles W/O so a bit of grinding on the way. Question pic is 1st gear which I ground most. I can tell contact on a few teeth not chipped just a SMALL bit worn. Syncros were 2000 miles from new small bit of metal in magnet. Replace?
Old 08-11-2010, 09:31 AM
definitely worn where the flats of the teeth contact the syncro ring. seen the cost of those things recently? probably will work still. seen way worse. how does the syncro look?
206 637 4071
Old 08-11-2010, 09:44 AM
Mark S
John I will be honest I only have a half a clue what I'm looking at
Old 08-11-2010, 04:50 PM
Under the radar
Trackrash's Avatar
Looks good to me, from the pictures. I would check the action of the synchro as mentioned.
The raised areas (red arrows) contact the synchro ring. Red arrows below.
You should not be able to turn the slider against the synchro ring when pushing them together trying to engage the teeth (black arrows) before the teeth engage.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-11-2010, 05:23 PM
Mark S
Got it, will check Gordon thanks.
Old 08-11-2010, 07:48 PM
