Can the factory dash wood trim option be removed from a 993? How?
Does anyone know if/how to remove the factory wood trim that came as an option with 993. Not the shifter/ebrake, but the dash around the gauges, ignition, radio/AC, airbag. Is it just glued on or is it actually part of the dash? Is there any way to remove it or would the entire dash have to be replaced? thanks!
Old 08-13-2010, 08:40 AM
