delkins's Avatar
targa top stowage
how do u targa owners stow your tops, i got mine on a hook hanging in the garage, do not put it on very often
1982sc targa blk on blk
va beach va
Old 09-05-2010, 06:46 AM
Nine9six's Avatar
Depending on how tall you are, and where you need your seat positioned; I stowed my behind my seat. That way it was alway with me in case I needed to secure the car.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-05-2010, 06:50 AM
Drisump's Avatar
If I stored the top off the car, say like you do, I'd hang it up "open". I believe that it being perpetually folded (stretched at the fold points) would not be good for the material.
Old 09-05-2010, 06:59 AM
5String
Oh, man, I've gotta try stowing mine behind the seats - a great idea, if it works with the seat all the way back, the way it must be for me. I've been putting mine in the trunk, where it eats up a lot of room.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 09-05-2010, 07:52 AM
Senior Member
Jdub's Avatar
I never fold mine into its storage state. I stow it in the "broken" position, with the front and rear arms just unlocked, but the material/arms not folded over. I use two "U" hooks in my garage and hang the top at the furthermost hinge points. This keeps it untensioned but not folded.
Fully folding a Targa top is what give you the two bumps just above the visors and hastens the wind noise. In fact, when storing a Targa model car, the top should not be fully locked to the car top, but instead just in the "clicked" state on the top of the car to prevent seal compression.
'78 Targa in Minerva Blue
Old 09-05-2010, 08:09 AM
HarryD's Avatar
I fold mine and put it in the trunk went it is not on the car (just as the factory intended). As far as I am concerned, I have no need to "save" it for the next owner. After all, why diminish my enjoyment?
And if after 37 years it needs a rebuild. So what? I can pay Dan about $1,000 to rebuild it. At a cost of $20/year, why worry?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-05-2010, 08:33 AM
Paul K's Avatar
When I had my targa, I had 2 tops. One 'folder' and one not.
The 'non-folder' was on a shelf in the garage when not in use.
The folder sat on the back seats with them folded down.
FWIW, the Carbrella top is a pretty handy accessory. I always thought the design needed a few tweaks, but handy to have...
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 09-05-2010, 08:38 AM
twistoffat's Avatar
I stow mine in the Trunk. The biggest issue with folding them is doing it correctly. I´m luck enough to have Orangutan arms so I can push with one and pull with the other to fold the frame. Many rest it on their feet and push and thats what causes problems
Old 09-05-2010, 08:40 AM
If I know it will not be needed, in the garage full open if questionable in the trunk just folded enough to fit.
I used to store it behind the seats (71) but I started noticing some skuffing to the interior material around the B pillars, so stopprd that. now the trunk.
Regards
Old 09-05-2010, 09:20 AM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
One thing that has kept me from putting it behind the seats is that it will rest open on the center tunnel.
That would be fine if the part resting on the center tunnel is the frame, but it wouldn't be, it would be the material of the top itself, and my worry is that it would become bent and deformed by riding on that fairly narrow point of contact, especially considering that it will likely be experiencing lots if bumps and heavy loads vertically and laterally as you drive along.
So, I either leave it unfolded in my garage, or I fold it up. The top's material is new enough to be fine with the flexing every once in a while.
I still need to get the top to dan for a full rebuild. I found in the records that the previous owner spent a lot of money having it recovered, but I don't think they did much else.
Now, if only I could save up the grand I need to do this.... But there are SO MANY TOYS that I want too.
Dammit, I was never good with saving money.
Michael
Old 09-05-2010, 09:35 AM
