-   -   SC poor performance (http://forums.pelicanparts.com/porsche-911-technical-forum/559405-sc-poor-performance.html)
johntom 08-17-2010 03:50 PM
SC poor performance
Hi
i have recently bought a 1980 3.0SC which has really poor accelaration, the car slowly builds up speed it never really pulls. The mileage is 107,000 with top end work done around 60,000.Th e oil pressre is good, over 1 bar per 1000rpm, there are no leaks, noises or smoke. I have changed the Dist. cap / rotor arm and plugs, accumulator, fuel filter, pump and check valve, the leads look quite new. None have made any difference. The car starts first time cold (around 900 rpm) but touching the throttle within the first few seconds would cause the car to stall. Warm tick over is around 800rpm (was 600 before i turned it up). Any likely causes for poor accelaration ?
Jdub 08-17-2010 04:01 PM
Assuming your tune up included a new air filter, plugs, a check on timing, and a valve job? Did the dist. rotor snap back to position, esp. after you oiled the felt? Any bad gas in your area? Do you notice a drop in idle when you remove the oil cap when idling - if not be sure to check the pop-off in the airbox and the overall condition of the airbox (ie not blown). When you start the car, put your foot on the brake pedal and ensure it moves away from you as vacuum is applied from the crankcase.
Sorry not to be of more help but hard to spec. from your description. It sounds to me like timing or some sort of intake blockage?
T-Bone911 08-17-2010 04:09 PM
Blocked cat? remove and see if that helps.
zacharyminot 08-17-2010 04:28 PM
Cat's a possibility. I had some fuel injection work done last year & when I got the car back it was a full 40% slower than when I dropped it off (despite brand new fuel injectors). While diagnosing the problem the shop ended up melting the catalytic converter.
Needless to say I've got a new (awesome) shop. Took a broomstick through it & now everything runs great.
psalt 08-17-2010 04:47 PM
johntom,
The first thing to check is the throttle linkage. I am amazed at how many 911 owners want to modify cars that don't have throttles that fully open.... Have your lovely assistant Tabitha mash the pedal and check if you can open it more at the TB. Then start replacing the bushings. Once you have full throttle, then check high speed timing and the FV duty cycle.
Paul
rhogg 08-17-2010 04:50 PM
I had similar symptoms and new plug wires cleared things right up. It is amazing how much more power a couple of extra cylinders provide. It was smoother too! :rolleyes:
Bob Kontak 08-17-2010 05:51 PM
This is a stretch. Make sure there is not a 3mm allen wrench in your CO adjustment screw that someone forgot to pull out.
crustychief 08-17-2010 07:59 PM
Have you driven any other SC before? A serious question with no ill intentions.
BTW was your fuel pump issue resolved?
aigel 08-17-2010 09:02 PM
Yeah, I had the same problem on my SC. ;) Seriously, what are you comparing it to? A stock SC isn't the fastest 0-60 car if compared to any of today's sporty cars.
I would definitely check the mixture. Also make sure you have the timing right and fresh gas in the tank.
George
johntom 08-18-2010 06:51 AM
Hi I wasn't comparing the car to anything, it just feels lethargic, nothing really happens when you put your foot down, Even at 70 ish and 3000rpm it just builds up speed with no Urgency. I forgot to mention that the car also backfires when lifting off the throttle, but not all the time. The airbox looks good but there is a preformed hole, about 1/2", on the left hand side, should that be there or sealed? The car doesn't have a cat and the previous owner removed the air pump. I will try the idle with the oil cap removed.
stlrj 08-18-2010 07:01 AM
It might be as simple as no power to the frequency valve control unit. The search feature could be your friend.
BK911 08-18-2010 07:07 AM
If it were me, I would:
Do a leakdown test first. This will determine if the engine is healthy.
Check ignition next. Condition of everything ignition related. Set dwell and timing.
Finally fuel injection. Check / adjust CO.
I do those steps whenever I get a new car, even if it is running well. And only after I check the brakes, fuel lines and filters, bearings and suspension.
johntom 08-18-2010 07:28 AM
Hi what and where is the frequency valve control unit ? Thanks
Groesbeck Hurricane 08-18-2010 07:43 AM
the preformed hole is most likely where the pop-off valve should be. I would test the car by using something to block the hole, something your car will NOT suck up the injection system. If the car runs better with the hole plugged then you will need to buy a new pop-off valve.
You might also update your information so we can see where you are located. Someone might be able to come out and help you if they are close by.
gathomas 08-18-2010 08:15 AM
My bet is a clogged-up filter screen on the WUR intake line. Simple enough to take off the line and blow it out w/ some compressed air.
opata 08-18-2010 08:26 AM
Hello,
I have an 80sc...went through something similar. Mine ended up being some broken head studs...I wasn't getting any compression...course a compression test would show you that. Or pull the lower valve covers off and look....
Alan
johntom 08-18-2010 08:30 AM
the preformed hole is most likely where the pop-off valve should be. I would test the car by using something to block the hole, something your car will NOT suck up the injection system. If the car runs better with the hole plugged then you will need to buy a new pop-off valve.<br><br>You might also update your information so we can see where you are located. Someone might be able to come out and help you if they are close by.
Sorry, I meant the small round hole is in the left side wall of the airbox, not in the pop off valve (which is in the bottom of the airbox). Unfortunately I'm in the Uk.
Bob Kontak 08-18-2010 09:13 AM
Frequency valve is part of the O2 system. It squeezes and loosens fuel pressure to feed less or more fuel to the engine based on what the O2 sensor is telling the control box. It is in the picture in the middle - not the blue one - just up to the right from that. The blue one is the cold start valve.
I would check the timing advance as suggested above. The snap back test.http://forums.pelicanparts.com/uploa...1282148026.jpg
johntom 08-18-2010 10:16 AM
Hi
just out of interest i have arrowed the hole in the air box where the pipe shape is. The hole goes through the sidewall into the box. Is this correct? I don't have a cat. or O2 sensor so i won't have a frequency valve?http://forums.pelicanparts.com/uploa...1282151757.jpg
Bob Kontak 08-18-2010 12:42 PM
That is where the hose from the carbon canister should go. The hose will wrap around from the canister on the fender wall behind the oil tank.
I think you still will have a working frequency valve it just wont vary pressure - However, the control unit can still control the frequency valve to a degree like on cold start where it tells the frequency valve to maintain a duty cycle of 65% which is rich. A temp sensor tells the control unit when the car is warm and the O2 system should then take over in closed-loop mode. You have no O2 sensor so I think there is a default mode of 50% duty cycle. However, there is also a wide open throttle circuit that overrides the O2 sensor input so yor frequency valve will help you there.
Suggest you read this CIS primer. It's pretty interesting. Go to CIS Components and then the O2 Sensor / Lambda SYstem.
CIS Primer for the Porsche 911
Groesbeck Hurricane 08-18-2010 02:07 PM
Bob,
I wonder what would happen if he taped up the carbon canister feed? It is a small hole but could it not create a slight vacuum loss? Just wondering out loud here...
Johntom,
The frequency valve is still providing some control but it is likely just providing a standard loop as Bob states above.
Nothing at all wrong with being in the UK, wish I were there now!!!
There are UK members, they are likely not up at this hour though. I would update my location to UK and hopefully some of them will jump in to help as well.
Cheers,
Bob Kontak 08-18-2010 02:16 PM
Tape it - right now it is just sucking air (and dirt) in after the filter and before the air sensor. No false air issues.
Edit - professionals say you want the canister functional. Gasoline vapor can be vented into the atmosphere vs being filtered thru the canister - then back into the intake.
psalt 08-18-2010 05:39 PM
johntom,
If you have a ROW SC, you can ignore the advice about the lambda system.
Paul
Paulporsche 08-19-2010 05:37 AM
Have you had your CO checked? How about your control pressures (WUR)? A too rich mixture can cause exhaust popping on throttle back off. Sometimes people richen the mix to try to make up for other problems, like vacuum leaks or incorrect control pressures.
I think I read someone suggesting timing and distributor function, but I'm not sure if I noticed that you checked it.
Did you test or replace all ignition parts as part of your tuneup?
Bob Kontak 08-19-2010 04:31 PM
psalt is absolutely correct.
To be honest, I thought US and RoW cars both had the O2 system. I looked at the Porsche parts diagrams I have in pdf format and they show a picture of the O2 sensor for RoW cars but no corresponding parts listing. The only O2 part listed is the rubber grommet used to plug the drivers side inner fender hole the wire passes through on Lamda cars.
trond 08-19-2010 10:23 PM
my 80SC was gutless too, felt like maybe a 90 hp car. What I found was one bad spark plug connector and a maladjusted throttle cable giving it maybe 3/4 throttle only with the pedal to the floor. WIth that sorted it was still low on power especially in the midrange with no throttle response at all. It was lean surging and the exhaust tip was almost white and the CIS was obviously not working as it should. It was all cured by installing a tbitz EFI kit. After the install the car has sharp throttle response and dramatically more power especially in the midrange. It is in my opinion a much better option than throwing money at the out of date CIS. I recommend it for any CIS equipped 911 whether it is running good or not because of the added throttle response
johntom 09-11-2010 02:56 PM
Hi
I took the car to a local specialist to try and sort out the performance issues, he immediately said the car was running too rich. In fact the CO was around 6.9 so he reset it to 3 and adjusted the tickover to 900rpm. Before the adjustment the car backfired occassionally when taking your foot off the gas to change down the gearbox, now the backfires seem quieter but happen everytime when you take you foot completely off the gas - ie at the moment when the throttle closes ?
Would incorrect timing cause this?
Also whilst changing the hose from the oil filler to the intake i noticed that the air sensor plate doesnt sit perfectly square, there seems to be a gap at one side but not alround, is this correct ?
David Borden 09-13-2010 09:08 PM
clogged injectors?
DanielDudley 09-14-2010 06:21 AM
Did you try this ? SmileWavy
boyt911sc 09-14-2010 11:58 AM
CIS troubleshooting........
Originally Posted by johntom (Post 5555591)
Hi
johntom,
CIS engines are easy to maintain and will start on demand regardless of weather. But the key is keeping all CIS specs within reasonable variance. Don't expect the car to run great if you have it set incorrectly. The air sensor plate should be set precisely centered @ idle. Air gap all around it. The control and system pressures both at cold and warm should be closed to spec. And lastly, not being able to find an air leak does not mean you don't have a vacuum leak. There are so many spots and locations that could have an air leak specially at the rear side of the engine which is not accessible for inspection with the engine installed in the car. Many CIS owners have given up their CIS due to frustration and failure to keep the CIS running good!!!!
But what I found out from a few of these previous owners of CIS, is the lack of understanding and knowledge about CIS!!!!! They blame CIS engines to be difficult to maintain and unreliable. TRUE!!!! Simply because they lacked the knowledge about the system. Talking about outdated technology, carburated engines is pre-historic compared to fuel injection systems!!!!
One of the most blatant mistake commited today even by experience DIY guys or mechanics is tinkering the mixture screw without verifying or knowing the presence of vacuum leak/s in the system. Like in any other fuel injection system, fuel pressures and vacuum should not be compromised!!!!
TR Conway's engine. A Pelican member from NJ.
http://forums.pelicanparts.com/uploa...1284489537.jpg
J Wirth's engine. A Pelican member from PA.
http://forums.pelicanparts.com/uploa...1284489643.jpg
A. Tiongco's engine. A Pelican member from CT.
http://forums.pelicanparts.com/uploa...1284489795.jpg
T. Donato's engine. A Pelican member from PA.
http://forums.pelicanparts.com/uploa...1284489889.jpg
CIS troubleshooting is a lot of fun and I do it for free!!!! Avoid the quess work and you'll enjoy it like I do. BTW, this is just a hobby for me. I spend most of my free time in the golf course or travelling.
http://forums.pelicanparts.com/uploa...1284490222.jpg
Tony
