VIN Questions - '76 911S
The VIN tag in the driver's side door reads: 9116201133.
I know this is a 1976 911S Coupe, #1133 built. This is on one of those mettalized tags in the driver's door frame where the numerals are punched out in little holes. The manufacture date is listed 01/76. Two questions really: #1 - Seems like 1133 is too many cars to produce by the first month of the year.....or were '76 cars produced in late '75 as well, and so mine is not really "early" in that model year? #2 - Is there anything unique to my (assuming) "very early" 1976 car? I am hoping maybe it didn't come with thermal reactors... or possibly with the 11 blade fan? Far as I know the car has always been in California, but I have not done a Carfax on it. Any advise appreciated. Oh and also, is there an "Options" numbers tag on it somewhere?
Dan in Pasadena '76 911S Sahara Beige/Cork |
Yes, model year '76 was produced in in 1975 as well as 1976. My Targa is even later than yours. In 1976 only California cars had thermal reactors. In 1977 ALL 911's had them. No 2.7L cars came with 11 blade fans from the factory. To get a full option sheet on your car I think you have to purchase a Certificate of Authenticity from PCNA which has gotten quite expensive, I think. Your car certainly got the full galvanized body.
Howard
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Thanks Howard. Do you mean your Targa was produced even EARLIER than my Coupe or do you mean it is also from an early month in '76 with a higher serial number than I have?
My 76 targa was produced in 2/76 it was 1209 of the line
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
My rather late '76 Targa S/N is 1606; manufactured in April, 1976. I've only seen one later Targa S/N. How many others out there in Pelican-land are even later?
Howard
Work in Progress
just an fyi you cannot do a carfax on a car earlier than, i think, 1982 or so. I know I could not do a carfax on my 1980.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Mine is tagged with 6/76, and with the S/N # 2111
Bill MID9 #4 if i cant play with it ,,i dont want to own it |
Thanks for the info guys. I guess 01/76 isn't early at all!
Earlier then mine
Just think how CLOSE I came to the Promised Land here in California...1975 and no smog check. Man oh Man.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
For reference... I got a 12/75 build Coupe, 49 State with serial # 1001. Lou
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
My '76 911S Vin 9116200462, 9-75 build date.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
My car is 9116201131 only 2 away from yours.
Also January. I wonder what day of January. |
83 911 Production Cab #10
The CoA will provide the Production Completion Date as in; for my 83 Cab ser 0070: 11/27/1982
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
It was introduce in 1981
Production for the next year starts as early as June. The numbers are consecutive, but for each different style of the line. The 1976 first coupe, will be 0001, the first Targa will also be 0001. The difference will show up in the 0 or 1 after the year designation of the VIN.
Later cars even split the VIN to ROW and US. Bruce |
Interesting as mine is 9116300536 and I thought the build date was 12/75, but it should have been around September or October, huh? I need to check that...
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
FYI, a model year has to contain only one January.
That means you can start producing your car in February 1975 and continue until December 1976 and call ALL of the cars made a 1976 model year.
My coupe is 9116201519 03/76. Spent the first 20 years of its life in Reno.---No mods except
the fabricated headers that replace the thermal reacters and has an 11 blade fan. guess these were done sometime in its life. Sugar scoop headlights and one door mirror. sunroof.&windup windows--fairly original. |
