Anyone using this exhaust?
It's called a Stinger exhaust by Weltmeister. It is stainless and rediculously priced at $989 in a catalog parts seller we all know. I have never seen it in Pelican's catalog although i'm sure he could get it. It has a nifty mounting bracket but otherwise could be duplicated much cheaper in stainless and much, much cheaper in mild steel.
I am wondering how it flows and if having the exhaust merge at the end serves the same purpose as having a crossover. I thought i remembered seeing someones car here with one like it. Paul
My ignition is retarded. |
Hi Paul:
I saw no crossover in their design and without it, it certainly won't perform like a system that does. Its really too bad since it appears that they could have incorporated that feature in this product for the known benefits. ![]() That said, placement is critical and it would not be easy to package a crossover with those pipes routed like they are.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
For those of us who are not as exhaust savvy, what is a "crossover" and what does it do?
Thanks!
I grabbed this off of Rennsport's website awhile back. Don't know if Steve still makes them available, but you can see the crossover pipe that connects the two banks. Very nice. Shouldn't be too difficult to add to any header system. The trick would be in selecting the correct crossover tube size and length. Maybe some systems have smaller internal orifices as well. How much would your system be in stainless?
Crossover tubes increase low end torque and reduce exhaust decibels. Sherwood
Thats a good looking system, more complex than the Weltmeister deal. It looks like it incorporates a pair of these.
What is the advantage of a crossover?
A crossover is to mix the exhaust gasses from separate banks of cylinders before they get to the mufflers or exit the tail pipes.
Steve can certainly tell both of us how that balances the exhaust pulse and affects your torque curve because i dont know. You can buy nice crossovers like this for front engine cars that dont have the space constaints that we do.
Schleprock
I think Chad Plavan (CPlavan) has a stinger. His 2.5 sounds really mean with it.
Kevin L '86 Carrera "Larry" |
Paul
With more & more race tracks imposing db restrictions I doubt you could use the stinger at the top very often.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
Here's another configuration:
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
when you see the word crossover think of the Brit. term "balance tube" - it links the resonance between the two banks of cylinders to produce better power (aka torque if low) IFF it is done correctly
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
With respect to the crossover, SSI's don't have a crossover. They go into a dual in single out or dual in dual out muffler. Does the muffler act as a crossover prior to gas exit?
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
Best, Tom
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
Dr. Gas invented the crossover. It wasn't until Bobby Labonte went upside down that people realized what was going in with his exhaust. The following Monday morning people were studying pictures and calling Dr. Gas. The following link explains the theory. It's a lot more complicated than just putting a pipe into the system.
http://www.drgas.com/articles/art_syncronicity.php Richard Newton |
Calling "Dr. Gas" ?
Senior Member
Wonder how loud this puppy is? Bet its not "neighbour friendly" so to speak.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Not speaking with any authority, but the crossover might be more effective further upstream near the collectors than downstream near the exit.
Sherwood |
