-   -   stuck cases (http://forums.pelicanparts.com/porsche-911-technical-forum/55978-stuck-cases.html)
derkpitt 01-06-2002 08:06 AM
stuck cases
I have a friend who it installing timesert for his head bolts on a 2.7. And can't get the cases split apart. All fasteners are removed, but the cases wont split. Any ideas on how to split them?
Roland Kunz 01-07-2002 12:36 AM
Hello
You are sure you have all the bolts and nuts ?
The ones behind the flywheel and the one inside mainbearing 7 ( 15 mm nut ) accesible trough the cainramp opening. And the two hidden by the oilcooler ?
After that you just split the case with a wedge by hammering a slight preload on the casehalves inside the venttower.
Then use a mallet and tap the halves on the bosses overstanding on the lower end and on the alternatorstand. Start with the flywheelside as there at mainbearing 1 are two guiding tubes.
Don´t use muscle, use brains
Grüsse
derkpitt 01-07-2002 07:03 AM
Thanks Grüsse, I'll pass the info on to him.SmileWavy
911_Dude 01-08-2002 09:52 AM
Also, make sure all the washers are off. They're crush washers and tend to smush around the case studs. It will take a bit of Malletizing since a case sealant is used and if its 25 years old may be quite hard.
