-   -   How do you tell when an '82 alternator is on its way out? (http://forums.pelicanparts.com/porsche-911-technical-forum/559833-how-do-you-tell-when-82-alternator-its-way-out.html)
saurkraut 08-20-2010 10:15 AM
Is was driving my '82 930 the other night, and I thought that the lights got bright a couple times. I checked the belt, and it was a tad loose. So I tigntened it. A breif drive with EVERYTHING on and I saw no power fluctuations.
I just read in a Motorbooks Porsche buyers guide that this car has a 1,050 watt alternator. Appearently, some of these alternators like to overcharge the battery and burn out other stuff.
How do you check if its overcharging?
Karl
rnln 08-20-2010 10:50 AM
start the car, let it idle, measure the voltage. Usually it's around 14+ volts. If it's 15v or more, it's over charging. I don't remember the exact number but around there.
carreraken 08-20-2010 11:23 AM
Had similar symptoms when mine went out. Used a voltmeter to monitor the voltage and it would occasionally spike to 15v. Had the alternator replaced.
You can also get a cheap voltage monitor that plugs into the cigarette lighter - that's what I use now.
saurkraut 08-20-2010 11:35 AM
13.9 volts.
Geuss it was the loose belt.
Thanks!
