1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Just for fun bumper treatment
or Does this make my rear end look wide?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 08-25-2010, 12:44 PM
Poor-sche Lover's Avatar
I really like that look. That's what I did with my last one, though I never got around to sealing up the holes properly. I just painted some plastic plugs I got at the hardware store. I'm thinking about taking them off the new one too. It just cleans up the back so much.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 08-25-2010, 01:01 PM
Zeke's Avatar
I'm sure it looks great in person. That camera angle doesn't do justice.
Old 08-25-2010, 01:10 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I did the same thing to mine a few years ago....
but it just wasnt wide enough.....so I did this...
I like big butts I cannot lie....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 08-25-2010, 02:04 PM
1.367m later
KevinP73's Avatar
I like that you filled the gap that occurs when the accordian rubber is removed.
Old 08-25-2010, 02:31 PM
1.367m later
KevinP73's Avatar
Better angle for you milt.
Old 08-25-2010, 05:12 PM
enjefriy's Avatar
Hi all.
What do you do to smoothen the edges of the rubber strips. If I remember correctly, with the bumperette removed, the remaining strips exposed edges looks quite jagged.
Cheers all
Old 08-26-2010, 12:26 AM
Nope, they all look like that...at least the ones I've seen.
1986 3.2 Carrera
Old 08-26-2010, 05:20 AM
Yes, the edges of the rubber strips all look like that. Sometimes, though, the ends will not lay flat against the bumper since the screws are too far to the outside. I have heard of putting a new bolt through the strip, and finding a black plug to cover the hole. I just used some strong adhesive and glued down the edges.
Alan
Old 08-26-2010, 06:05 AM
Send a message via AIM to NoLift911
I like it - but I decided to go all the way
Jeff
Old 08-26-2010, 07:03 AM
