Lucky's Avatar
Question headlamp trim ring question
Will a painted trim ring currently in use on H1s also work with H4s? I'm thinking of parting with my H1s to raise cash for 16x9 Fuchs... figure I'll replace them with H4s.
Thanks in advance for the help.
-- John
'00 Boxster S
'86 Carrera Coupe (Sold)
Old 01-08-2002, 07:12 AM
Send a message via AIM to Oldporsche
Cool
The H1's outer ring has 4 reflector adjusting holes in it.
The H4's outer ring has 2 reflector adjusting holes in it.
Good luck,
David Duffield
Old 01-08-2002, 07:22 AM
Lucky's Avatar
I'm actually referring to the trim ring which covers the one with adjuster screws. It mounts with a single screw at the bottom.
-- John
'00 Boxster S
Old 01-08-2002, 07:50 AM
Early_S_Man's Avatar
Porsche Crest
John,
If you are talking about the paintable trim ring that clips over the H1 trim ring (with 4 adjusting screws and one retaining screw hole at the bottom) and only has the single retaining-screw hole at the bottom ... yes, it fits over the H4 trim ring with the two adjusting screws. And, also the original 1965 headlamp assemblies in the ad photo below, too!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-08-2002, 07:52 AM
Lucky's Avatar
Thanks Warren!
-- John
'00 Boxster S
Old 01-08-2002, 08:12 AM
