brooklyn ny 11234
1974 911 took cover off air filter
The whole air cleaner is full of oil and prior to taking off valve covers the car smoked like crazy now i know why has anyone had this problem i need a short cut fix dont want to start taking everything apart help
thx mike |
overfilled oil?
brooklyn ny 11234
Put 10 takes less
Taking it apart is easy
The airbox in my '74 had plenty oil in it, too, the first time I checked it. The generous PO had filled the oil tank right up to the full mark on the dipstick. Now at around half full things are fine.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
If you want to get over the oil on the airbox for a 74 to 77 and overfill isnt the problemyou need to getSC cover from the airflow sensor to the throttle body 930.110.358.05, the hose and connection to run to the oil tank neck replacing the hose from the neck to the airbox that leaves the oil in the airbox to drain to the top of the engine or into the small tube forward fo the sheet metal.
Bruce |
brooklyn ny 11234
i think the guy might have overfilled and not told me
thx |
brooklyn ny 11234
the hose your talking about is the big one from neck to housing you replace that one with that part number is that correct
winter
#1, drain some oil out.
#2, check/replace hose as suggested here. I think you have overfill problem, sounds like it. Run is 1/2 to 1/4 way above min on dipstick. Hopefully will solve your problem and will prove to be one of the easiest fixes you've ever done to solve problem with your car. You already know this, but check oil on level ground with car running and up to temp. Good luck.
Tom '76 Targa |
brooklyn ny 11234
thank you for all your help it was over fill
thx again everyone |
Here is a picture of the original dip stick for a '74 with the replacement stick used when changing the sending unit in the oil tank. You can see the lower oil level on the new stick.
brooklyn ny 11234
so it like let say 1-2 quarts lower is that correct
thx mike |
Not that much, a complete oil change in my '74 emptying both the tank and crank case it takes 11 quarts and will be just below the full mark on new stick. If you fill half way between full and add on the old style stick that will work good. Just make sure the oil is warm enough.
brooklyn ny 11234
thank you very much
