Loose steering wheel?
As I was driving my 81 911 sc I noticed that I was getting increasing play in the steering wheel, not loose like you would turn the car, but loose if you grabbed the side of the wheel and moved it forward and back. I removed the horn and the wheel nut is tight. It appears that the "shaft" has a great deal of play in it, more than normal. Where is the next connection area? Is something broke or loosening up? What should I look for? Thanks
Old 08-18-2010, 07:27 PM
scottb's Avatar
Common problem. Do a search here on the BBS for "steering column bushing" (without the quotation marks).
There are two "fix" bushings. One is a metal insert. The other is another material (made by our own Mitch Leland). The metal one used to be the fix of choice, but Mitch's seems to be gaining popularity. I believe our host sells both parts.
It's about a 30 minute job, and not difficult.
1984 Targa
Old 08-18-2010, 07:55 PM
Cool, thanks, I'll start searching
Old 08-18-2010, 08:21 PM
Make sure you read the reviews before deciding which to use.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 08-18-2010, 08:24 PM
Just bought the Mitch Leland one. Looking forward to get this problem fixed. Thanks again
Old 08-18-2010, 08:42 PM
Mitch Leland's Avatar
Steering Support Bushing...
Nine 51,
I'm sure you'll be very happy with your new bushing... The best part is that it's probably a life time fix, it won't rattle, and best of all if you ever have to remove it, you can...
If you have any questions on the install, just PM me... remember you won't go back with the "star washer", just put it in your parts bin... The directions are complete!
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 08-18-2010, 09:14 PM
Received my bushing over the weekend and installed it last night. No complications whatsoever. Just followed the steps and had my problem fixed in less than 30 minutes. Its nice when a project "works". Thanks again to this board and Mitch Leland
Old 08-24-2010, 08:14 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Must be having a M.M.
Originally Posted by Mitch Leland View Post
Nine 51,
Mitch
Can not find the part # for yours
Standing by...
J.J.
Who Will Live... Will See
Old 08-25-2010, 02:27 AM
Here it is: PEL-ML-STR. For some reason, Pelican has it a bit lower on the page than the metal sleeve. (it is with the lower support bushing.)
Scott Wilburn
1998 M3
1984 308 QV
Old 08-25-2010, 05:36 AM
JJ 911SC's Avatar
Merci..
Scott
J.J.
Old 08-25-2010, 06:07 AM
J.J.
Just in case you need any more information on ordering:
Pelican Parts - Product Information: PEL-ML-STR
Feel free to PM if you have any additional questions on installing...
Mitch Leland
Old 08-25-2010, 08:51 AM
JJ 911SC's Avatar
J.J.
Mitch
Thanks, the order will be place tonight. I need to go in there as I got a dead horn at dead center and my flasher arm are not returning, so it's will be perfect timing.
Cheers
J.J.
Old 08-25-2010, 10:05 AM
loose steering wheel-mitch leland bushing fix=great
I just did the Mitch Leland bushing fix on my '88 Carrera. Just as advertised it was a piece of cake to do. Good clear instructions and very easy fix. As he notes, use a little pick, piece of wire, etc to remove the little broken chips of the old bushing but any left behind just get pushed down the column and out of the way by the new bushing so not really an issue. Also like the fact that with the allen head screws you could remove it if required.
I used a piece of white PVC sprinker pipe(which came with a factory flare on the end(1-1/16 I.D.and 1-5/16 O.D.) to tap the new bushing in.
Steering is now good as new. A great part, and lots of good info about it from other happy users on this thread. That's the good thing about Pelican. Someone in the community has nearly always tackled whatever you are facing. And often a good aftermarket fix avaiilable. (I did the WEVO Rear stabilzer bar fix earlier this year-via Thom Amon San Jose). Now if I could find them same hi-quality level of Pelican info for Saab as for Porsche i'd really be happy.
Old 08-28-2010, 01:55 PM
Basher, thanks for the kudos and the PVC install tip...
Oh, you might add to your "public profile" where you park your car (well approximately), never know you might have some Pelicans in the neighborhood...
Mitch Leland
Old 08-28-2010, 02:39 PM
