![]() I just had a request for the (3) fuel hose assys on a 78 930 that go from the tunnel to the pump to the engine & back to the tunnel. It seems that only one is available at Porsche. The lines in question are ........ Supply from tunnel to Pump: ![]() Pressure line from pump: ![]() and the return hose from the top of the CIS back to the tunnel: ![]() This last hose I just made up, but I would have to order the correct 180 deg fittings to make the other hose assys for this application. I have lots of fittings, even some 180's but not this size. ![]() My question is........Is there any demand to justify the expense & time delay to special order the 180 deg fittings just to make up a few lines? Anyone else need something similar for their 911? Len at autosportengineering dot com
![]() Update: Just ckd w Porsche, and the top two lines w the 180 deg ends are now available. The bottom (return) line is s/o Germany, but this is the one we have been able to make up. So...Emergency over for now.
![]() Update, I now have the 180's in stock, so I can make up hoses w the 180 deg fitting......... ![]() Also have the Banjo hose ends but no photo yet. Len
