For those that removed the bumperettes
I'm just finishing off a much needed rear face lift. Everything has gone pretty smoothly, aside from the hideous gap i have from the rear rubber moldings.
I've seen others examples and was curious how you guys get the rubber molding to sit flush with the inner part of the bumper. Is adding another screw my only option?!?! They are brand new as well.
Pic below of the gap! Thanks in advance!!
Old 09-30-2010, 02:16 PM
Friend of Warren
You can drill through the rub strip and screw into the bumper to pull in the rub strip and use a black plug to hide the screw or take the bumper off and drill through the inside of the bumper and slightly into the rub strip then use a sheet metal screw to pull in the rub strip.
Kurt V
Old 09-30-2010, 02:50 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
I would first try the 3M double-sided tape stuff that is used to stick badges and stuff to cars these days. If it does not hold, then you have an easy clean up before trying something that involves drilling etc...
I used that to fit my number plate on the front, and had a real hard time getting it off again!
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 09-30-2010, 10:21 PM
andyu911's Avatar
+1 3M double sized tape. It works really well.
Andy
-'87 Carrera -'73 914 2.0
-'06 Frontier -'02 VW Golf TDI
-'07 GT3 RS -'07 Top Kart KPV-4
Old 09-30-2010, 11:20 PM
GBStu's Avatar
I took the rubber strips off:
Thx, Stu
Old 10-01-2010, 07:09 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Here are (2) more options:
What I was planning on doing: Drill a small hole in the bumper and put in a short (but coarse-threaded) sheet metal screw into the rubber strip from the inside of the bumper - that way it doesn't show.
And what I actually did: With the rubber strip off the car, I bent the rubber strip in a makeshift fixture and applied a little heat for an extended period of time to "shape set" the part to a more bumper-conforming shape. (Luckily, my wife won't see this and find out that I used her oven.)
Old 10-01-2010, 09:37 AM
juan ruiz's Avatar
Loctitte 404 is your friend
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 10-01-2010, 10:04 AM
Flaake's Avatar
dw1, where did you buy the license plate lights?
Thomas
Old 10-01-2010, 02:55 PM
