Installing Fog Lights thru horn grills
Does anyone have a documented project or a diagram to install fog lights in the horn grills on a non-fog light car from the factory (a 1970 911T).
What are the requirements. Any fuse box issues, toggle switch/pull-out dash parts. I have fog lights, wire, and mounts for the "thru horn grills". Vr, Bavaria911 |
You will find all the info you need at the Early Porsche forum:
Early 911S Registry Bulletin Board - Powered by vBulletin John |
| All times are GMT -8. The time now is 03:55 PM. |
