Plastic Door Handles - Where to find
[Edit] Who can identify this car? The various handle leads didn't match and imply these handles may be custom, but wanted to make sure. Probably best to find the car. Last seen in Nortehrn California. Anyone have any clues? [Edit]
Wondering if anyone can hint at where these might be available.
This was actually captured off of a 912.
The owner may want to have the only car with these.
They may even be custom, our of nylon, fiberglass, etc.
He did a nice job with this "outlaw" 912.
thank you in advance!
Old 09-01-2010, 05:43 PM
some more detail - / hints - window trim matches door handle material
Car was spotted in Northern California
Old 09-01-2010, 05:48 PM
Bandwidth AbUser
Jim Richards's Avatar
I have a pair of plastic handles (no pushbuttons or lock cylinders) that are the later style, like you'd see on a 72/73. I'm not going to use them.
Jim R.
Old 09-01-2010, 05:49 PM
Bye, Bye.
Scooter's Avatar
Do a search for TRE Motorsports.
Elvis has left the building.
Old 09-01-2010, 06:20 PM
thank you both - it is for a friend - will ask about the your offer
911 R Plastic door handles- outer key type
Item: 901-202
$145.00 Quantity:
These precision cast plastic handles accept the original key inserts from the 1965-1968 models. Allows you to lock your car while reaping the benefits of the ultra light handles (2 ounces each). These will allow you to engage the original inner door mechanisms. They also come with spring loaded inserts for those owners not requiring locks
Check 911R handles 69-89 for later model chassis
Sold per pair
Van Nuys, CA 91406. Phone: 818-909-9220. Fax: 818-509-2638. Visit Our Website ». Ha
Old 09-01-2010, 09:10 PM
Switched gears to finding the owner of the car. Loking for the drilled handles and none seem to match.
Old 09-02-2010, 07:48 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Pretty sure he drilled the handles himself.
To find the owner of the car, you will find him on the 912 Registry boards.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 09-02-2010, 08:55 AM
