pokeytom's Avatar
1977 911s
New fuel distributer, injectors and plugs. Car runs for about ten minutes then quits????? Where do I go from here?
Old 09-02-2010, 05:25 PM
fuel filter???
1975 Carrera #116 3.6 guards red sold
1980 911sc Talbot Yellow got back!! 1978 911sc 3.6 Sold
1996 993 tt white Sold. 1997 993tt red Sold 1986 930 sold
1986 491 Prussian blue sold 2002 tt white sold
1996 993tt adventurine/gray 1987 carrera with a 3.8
Old 09-02-2010, 05:38 PM
first the filter and then the pump, pressure test to see the 10 minutes til it stalls
Bruce
Old 09-02-2010, 05:54 PM
pokeytom's Avatar
New fuel tank, flushed lines and filter.
Old 09-02-2010, 06:16 PM
Does it re-start easily or not for some time?
If it doesn't re-start easily, you need compression, fuel and spark for it to run - what's missing?
'77 S with '78 930 power and a few other things.
Old 09-02-2010, 07:17 PM
T77911S's Avatar
wow, you have spent some money. just curious, why a new FD?
when it quits, does it restart as asked from above? does it quit from an idle or are you driving the car? will it keep running if you try to hold the RPM's up? is it slow to die or does it just stop?
if it does not restart, check for spark by pulling a a wire and connecting a plug to it. if it has spark, pop an injector out, put it in a jar, key on and lift sensor plate to check for fuel. does the fuel pump still run when it cuts off? we need details.
what about the WUR. new, old, anything done to it? is the screen on top clean?
is there 12v to the WUR? have you checked fuel pressures warm and cold. my thought here is that if you have no 12v to the WUR, as it warms from the engine, and the WCP is not right, that could make it cut off.
what did you do about the vacuum enrichment to the WUR? is it connected? is the thermo time valve still connected?
this should keep you busy
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-03-2010, 04:37 AM
Had the same problem traced out to warm up regulator
1983 911 SC
Old 09-03-2010, 05:02 AM
