Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
From the picture, looks similar to my original Gemini metallic blue, but it's hard to tell....
Old 09-03-2010, 03:12 AM
djpateman's Avatar
First, how did you establish that it was Lhasa when you first posted about that?
The code written into the booklet is a marketing code for the color, not the color code itself.
Look for labels such as pictured or mentioned here:
Paint Code
In some 1982 cars is stuck right in the engine bay. It is one of the many stickers that lines the leading edge of the engine bay support, where the engine lid latch connects to.
It is the three digit code that you need to find: xxx or Lxxx.
If you find that code on the decal:
then the name will be spelled out and the two digit marketing code is on the lower line. The marketing code (2 digit) is doubled for a coupe, and is what is written in your record booklet. Take photos and post them so that the codes can be documented for others.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-03-2010, 09:00 AM
MBruns for President
JeremyD's Avatar
Looks like light blue to me - I's say paint it whatever freakin color you want.
Old 09-03-2010, 09:14 AM
Senior Advisor
James Brown's Avatar
JeremyD, is your Arrow Blue a single stage paint? I so want mine that color.
08 Cayenne Turbo
Old 09-03-2010, 09:26 AM
JeremyD's Avatar
This is what I found out about my car - emailed from another pelicanite
Body sandblasted to metal top and bottom
Minor repairs done to body (was in excellent shape with no rust)
New undercoating
2 coats of primer to top and bottom
1 coat of sealer to top and bottom
4 coats of Deltron Porsche blue to top and bottom
All body parts were striped and painted separate from body, then installed with new rubber.
Old 09-03-2010, 09:57 AM
fritzgator's Avatar
heres slate blue on 83
Gator
99 996 c4
Old 09-03-2010, 10:02 AM
AutoBahned
RWebb's Avatar
no way is that Gemini, Arrow, Gulf, or some of the others that people are just throwing out
find the sticker itself and see what that says - if it is a custom # then you are still in trouble
you can get a quality shop to use a reader/gun to analyze the color, which has no doubt faded from sun exposure any way
Old 09-03-2010, 11:40 AM
James, my SC is single stage Glasurit in arrow blue.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 09-03-2010, 04:56 PM
NewfieMZ3's Avatar
My .02
My vote is Slate Blue.......L661
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 09-03-2010, 05:30 PM
Surely there must be a table somewhere that links the paint number to the color code? I remember I had the same frustration on my '83SC as the paint code label was long gone. Here is an example for 912 colors:
http://www.912registry.org/restore/pcode.htm
Old 09-03-2010, 06:31 PM
Senior Advisor
Stunning (every Arrow Blue car) The only code that fits (2nd and 4th digit is a 7) is a yellow! that is on the 912 paint code, B7B7.
08 Cayenne Turbo
Old 09-03-2010, 08:09 PM
I guess there is always the possibility that the person at the dealership filled in the manual wrong
Here are the close matches -
U7U7 = Schwarz (black) metallic [LM9Y]
U2U2 = Hellblau (light blue) metallic [30T]
W7W7 = Pazificblau (Pacific blue) metallic [31G]
Call me crazy but I have always wondered if an exterior color may have changed on the production line? Reason being is that until recently I owned an '82 928 that I purchased from the original owner at 29,000miles. Zero accident history. The exterior was pacific blue metallic which is a fairly dark blue/grey color. One of the wheel wells was painted this color and the other 3 were a much lighter metallic blue about the shade of hellblau metallic. Not noticeable unless you had the car on a lift. The rear hatch interior under the carpet was also painted in this lighter blue color. I wondered if someone special ordered a color and then canceled the order once the car was painted would the factory change the color of a car if it had not left the paint shop? The other scenario would be if there were paint flaws that required a complete repaint would they strip the paint and send it back to the beginning of the paintshop line whereupon it may end up with a different exterior color to what might be showing inside the tub?
Old 09-04-2010, 05:49 AM
Max Sluiter
Flieger's Avatar
Just doing a handwriting comparison, we see an example of his W, 7, and 2. Based on that, I can only interpret the writing as "U7U7".
You are sure that is the original color under the seats?
I believe that Cobalt Blue Metallic has a black base, then a blue, then some metallic, then clearcoat. Could the color under the seats just be the metallic part of the black?
Old 09-04-2010, 10:33 AM
2002 996 C4S
jcsjcs's Avatar
Where is the option code list on an 84 911? I checked under the front and rear hoods, on the driver's and passenger door jambs. I have a VIN metal sticker, but no options.
My car was built in 9/83 and I am finding some strange inconsistencies in what options I have vs. what people say was available.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 11-14-2010, 06:14 AM
It's U2U2, "Light Metallic Blue".
Old 11-14-2010, 09:17 AM
+1 for U2U2 light blue metallic. I had an SC in this colour and it looks like the perfect match of your rear seat area.
HTH
Old 11-14-2010, 09:55 AM
