-   -   Turn Signal/High Bean Switch wiring question (http://forums.pelicanparts.com/porsche-911-technical-forum/562588-turn-signal-high-bean-switch-wiring-question.html)
Peter Seow 09-04-2010 12:59 PM
The PO did not wire them correct I believe,
Is this wiring done wrong the yellow wire with female connector shown in the picture was wiring to no.56 of the light switch. The Black/White wire is also connected to no.56
The Red/White wire shown was connectted to no.30 of the headlight switch, I can use the high beam flash BUT the high beam on permanently cannot work,
I lost track of the wires grey and white and grey and red where should they be connected?
Should the yellow female be connect to the yellow male that makes more sense?
http://img1.classistatic.com/cps/kj/...161610_20.jpeg
http://img1.classistatic.com/cps/kj/...403l1b_20.jpeg
Peter Seow 09-05-2010 08:02 AM
Folk it fine now i managed to trace everything back
