Wash. State
nesslar's Avatar
DOT approved or Euro?
Since I've always loved the word "edumacate", please do so for me!
I have H4s I bought a few years ago and installed them. I don't recall what was written inside, but the lenses have no mention of "DOT" on them. The lights are single lamp, but really do light the street up; VERY pleased with them. In fact I can't imagine anyone needing more visibility at night. If the lights are USA spec., wouldn't there be some indication?
Old 02-05-2011, 07:12 AM
Drisump's Avatar
They are probably not DOT....if you're pleased with them, LOL. DOT regs make the lighting (especially on low)much more scattered, to illuminate large signs on a motorway. The Euro's have a strong cut off and up on an angle to the right. This is to minimize "flashing" oncoming cars, and (the angled bit) to illuminate the roadside. Don't understand why North America continues to make lights in this way, the rest of the world doesn't. Cheers
Old 02-05-2011, 07:24 AM
moneymanager's Avatar
I believe European lamps have an "E" or maybe ECE in the bulb, the so-called E code; mine do. DOT lamps say DOT.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 02-05-2011, 07:45 AM
DOT might still have the tits on the outside of the lens for a lens alignment tool to fit
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-05-2011, 07:54 AM
RETIRED
Joe Bob's Avatar
Nope, not DOT approved. With the HID mods on the ricers, you'll have a lower chance of getting yanked over.
The Bosch relay kits bumps them up pretty good. So does going with a higher wattage bulb.
2012 ML350 3.0 Turbo Diesel
Old 02-05-2011, 09:29 AM
Wash. State
nesslar's Avatar
Yep; the "e" is there alright. So I guess these were impoted to sell, which of course they did (to me from a retailer online), about $315 for the set, new, and I really do like them. Quite bright.
Old 02-06-2011, 06:44 AM
They are very good headlights, enjoy.
jhtaylor
santa barbara
Old 02-06-2011, 06:51 AM
There are NOT any DOT approved H4 lights.
There are 2 kinds of H4 lights for 911's.
a. Ones that fit into the 'sugar scoops' where the DOT approved sealed beams used to be.
b. The Euro H4's that look very different, remove all the sugar scoop and fixture.
There are H5 headlights that look like the Euro H4's and are DOT approved, but they are inferior to the H4 lights.
Old 02-06-2011, 11:08 AM
I just purchased and installed two new Hella DOT-approved H4 headlights for my '69S. Even retained the "sugar-scoop." Very simple install. BB Purchased from our host.
Last edited by badbilly1; 02-06-2011 at 11:50 AM.. Reason: Purchased from our host. Added.
Old 02-06-2011, 11:49 AM
Gordo2's Avatar
DOT approved H4's
I don't think this is the case.
Hella makes DOT approved H4's - Pelican carries them (PEL-H4-70477). Hella makes both DOT approved and E-code H4's. Both have the same form & fit (they both retain the sugar scoops), but the E-codes have a different cut/beam pattern on the lens.
I can't speak to performance differences between the Hella DOT H4's and E-Codes. I've only used the E-codes and they are a huge upgrade over the stock sealed beam units.
The Hella DOT H4 lamps use the H4 bulb (hence they are in fact an H4 vice H5 headlamp). The H4 bulb is not interchangeable with H5's (the body/fitting of the H5 bulb is slightly larger than the H4)
Then of course there are the Bosch Euro lamps (E-code as well, Euro or E-code is the European equivalent of DOT in that it is a standard) that don't retain the sugar scoops. These also use the H4 bulb.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 02-06-2011, 07:37 PM
